John Deere 820 wont run.
/ John Deere 820 wont run. #1
banditman
Member
john deere
I have a john deere 820 with a 4 cylinder diesel engine that we rake with. The tractor started to die every few mins so i changed the fuel filters and now it dies every 30 seconds or so. It starts fine and you can rev it up but it dies in a few seconds. Any ideas what is wrong?
/ John Deere 820 wont run. #2
banditman
Interesting how you managed to get a 4 cyl diesel when the 820 is a 3 cyl Yanmar. Maybe you meant 3 cyl.
Look for contaminated fuel in the tank. May have algae which can cause supply problems. Will need to follow the fuel lines back to the tank and be sure there is no restriction in the flow.
Also, check that the vent in the fuel cap is not plugged. But that usually shows up as a shutdown after a longer period of run time.
Be assured that there is no air in the system. The manual will tell how to check that out after filter change, I believe.
/ John Deere 820 wont run. #3
Check to see if fuel return line or return line fitting that attaches to IP is plugged. If fuel is controlled by electric solenoid it could be the problem.
/ John Deere 820 wont run. #4
banditman
Interesting as I've never seen a Yanmar engine in a 820. Maybe you meant Saran
/ John Deere 820 wont run. #7
Did you bleed the fuel system after changing the fuel filters? Sounds like air trapped in the fuel lines somewhere.
sorry meant 3 cylinder. Beld the entire system I have fuel clear through the system but still the same symptoms. I think maybe the alternator is going bad could that cause the fuel shutoff to turn the engine off due to low voltage?
/ John Deere 820 wont run. #9
Is there low voltage? How low?
/ John Deere 820 wont run. #10
Do you have to jump battery to get engine t start after it dies? I still think you have a plugged return fitting or line.
/ John Deere 820 wont run. #11
Could it be a bad fuel pump? Did you check the crankcase for "extra" oil?
/ John Deere 820 wont run. #12
Does this tractor have a fuel solenoid? If so prove the fuel delivery system and then start looking at the electrical systems and shutoff's if it has those.
I tried hooking up a battery charger to the tractor to see if it was a voltage problem but it still does the same thing. Im not sure how the shut off works on these tractors there is no selonoid on the out side of the pump like on a piston pump this tractor has a rotary pump. The lift pump is leaking is leaking but it is pumping could this be the problem that it is not pumping enough fuel?
/ John Deere 820 wont run. #14
banditman
Which IP does our tractor have? Here's a parts photo of 1 the Roosamaster IP electric solenoids(parts key 9)
It has the roosamaster injection pump
/ John Deere 820 wont run. #16
If the lift pump is leaking I would change it out, about $40 from NAPA iirc. I would check for 12 volts to the terminal wire on the injector pump and ground. I would use a meter to determine whether the 12 volts is constant to the solenoid when the engine dies. A 12volt test lamp probe could be substituted if you don't have a meter and should glow when the ignition switch is turned on and should stay lit while in place.
Did you check the return line as Jim recommended? That is an important point to consider and Jim is a retired shop foreman and Deere mechanic. I recommend you follow his advice.
When you have compound problems it can be confusing which is the culprit. If you start with a fully charged good battery it should be able to run the fuel solenoid for quite a while so that would eliminate the voltage issue.
I would change the lift pump if it leaks because it may be sucking in air causing your problem but more importantly it may be leaking diesel into the crankcase thinning the oil.
I would also (out of curiosity) take a fuel sample from the bottom of the tank in a clear glass to see what the fuel looks like. There should be a petcock there for this purpose. My 820 had one and had a fuel cut off there too.
Just found that there is diesel in the oil. So does that mean that it is the lift pump or the injection pump?
/ John Deere 820 wont run. #18
Diesel fuel in crankcase could be from lift pump or IP.If it was my tractor I'd change lift pump 1st because it the easiest to change.
/ John Deere 820 wont run. #19
I had this issue with my 820 several years ago. I think it could be either, but I was advised to replace the lift pump first as it was the more likely culprit and much cheaper than replacing or rebuilding the injection pump. I replaced the lift pump and haven't had a problem since.
/ John Deere 820 wont run. #20
banditman
It's a three cylinder 300 series Dubuqe/Mannheim/Saran not a Yammer Hammer.
New/Unused Wolverine 78in Quick Attach Smooth Bucket (A65583)
New/Unused...
1996 Great Dane 50' x 102" Reefer Trailer (A62613)
1996 Great Dane...
2007 Ford Crown Victoria Sedan (A61574)
2007 Ford Crown...
X-STAR 30,000lb Ramp (A64119)
X-STAR 30,000lb...
3Pt Backhoe (A66285)
2006 Ford F-150 Ext. Cab Pickup Truck (A61573)
2006 Ford F-150...
