FORD 2000 HYDRAULICS PROBLEM (DRAFT?)
   / FORD 2000 HYDRAULICS PROBLEM (DRAFT?) #1
hkhutson
chiefland, fl
ford 2000
I was using a box blade when i hit a buried stump. I wasnt going fast but it still hit hard enough to stop the tractor. Anyway, from that point on the lift doesnt function right. It will lift all the way up and stay up with no problem, or it will go all the way down (more or less) with no problem, but it wont stay anywhere in between. Also, the control lever now feels like it's spring loaded in the up position. It'll stay in the down position if you put it there, but if you just bump it, itll spring back the the up position. Havent had any problems with the machine until now.
What have I done to my machine?!
   / FORD 2000 HYDRAULICS PROBLEM (DRAFT?) #2
It may have hit hard enough to flip the draft control lever, into position mode.
Well I flipped the lever back and forth but I can't get it to do anything else...nothing changes. Is there something I'm not doing? I'm not a tractor pro by any means.
   / FORD 2000 HYDRAULICS PROBLEM (DRAFT?) #4
Sounds like the lift cover is coming off.
2004 CATERPILLAR 963C CRAWLER LOADER (A51242)
2004 CATERPILLAR...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
2017 Crane Carrier Co LET2 Side Loader Garbage Truck (A48081)
2017 Crane Carrier...
Headache Rack (A50860)
2000 PETERBILT 379 FLATBED TRUCK (INOPERABLE) (A50854)
2000 PETERBILT 379...
2023 Ford Explorer AWD Hybrid SUV (A48082)
2023 Ford Explorer...
