Before snow plowing..
/ Before snow plowing.. #1
bcp
Super Star Member
SW WA
Kubota BX2360
There was snow rolling.
Bruce
/ Before snow plowing.. #2
Thanks for sharing , nice pictures .
/ Before snow plowing.. #3
Why did they role it? Didn't that make it slicker than snot.
/ Before snow plowing.. #5
By the size of those teams, those rollers must have had some weight.
Never knew about this practice, but when you think about getting around in a sleigh, it makes perfect sense.
/ Before snow plowing.. #6
Exactly = A better surface for sleigh or sledge.
Well, that makes sense. I assumed they were using wagons or old trucks.
/ Before snow plowing.. #7
Yup, certainly does make sense. I'm guessing it takes far less power to pull the roller than a similar width plow. You never run out of room going up and don't have an ever increasing plow ridge contributing to drifting.
Pretty sure my dad told me they were still doing this is parts of rural Manitoba in the mid 1900s
/ Before snow plowing.. #8
Sure do like viewing yester years pics...thanks.
/ Before snow plowing.. #9
Some farmers around here still use a drag to flatten the snow in their yard, same idea as the roller. Works great until spring or an early thaw, then less than great as your 2 foot thick roadway slowly dissolves!
/ Before snow plowing.. #10
Snow was rolled here in rural Quebec in the '40's as well.
Once packed down cars could drive on that frozen base but come spring thaw nothing could circulate for about 2 weeks.
Bombardier became famous because he designed tracked drive train with skis for steering up front.
From snow sleds the have progressed to world class jet aircraft.
/ Before snow plowing.. #11
I seem to recall hearing about a city in AK (Anchorage?) that used to roll all the snow on their streets. Then, one year, they invested a ton of $ in "modern" snow removal equipment... and all the under-street utilities froze because they lost all of their insulation. Oops!
Don't know if the story was true or not, but it makes sense.
/ Before snow plowing.. #13
We used to use a wood pole as a drag. It worked quite well but like others have noted spring thaw was a slushy time. We'd often pull it down the road after the snow blower had went through opening it up. This would knock down the snow on the sides and reduce the tendency for the snow to blow in and build up deeper.
/ Before snow plowing.. #14
Cool pictures
Thanks for sharing
2018 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2018 KENWORTH T680...
IRANCH Tire Changing Machine (A64194)
IRANCH Tire...
2019 Cub Cadet Ultima ZT 1 50in Zero Turn Mower. (A64557)
2019 Cub Cadet...
2018 Freightliner Thor Venetian 400XCR A40 41ft. Class A Motorhome (A64557)
2018 Freightliner...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
2016 CATERPILLAR 299D2 SKID STEER (A63276)
2016 CATERPILLAR...
