yanmar ym2000
/ yanmar ym2000 #1
curtis cothran
ashland city TN
yanmar
i am new to the forum and will probably get lost. i recently acquired a green YM2000 tractor that has been setting for several years. the previous owner parked it and when he went to start it it would not start. it set for several years before i bought it. cleaned the fuel tank, installed new lines, filter etc... i am getting a good supply of fuel to the injector pump but nothing out when cranking. fuel tank is full. everything i have looked at is clean in the engine. any advice would be appreciated.
/ yanmar ym2000 #2
Welcome to the forum. :welcome: Wouldn't suprise me if the rack on the fuel pump is stuck or even the plungers. I would pull the inspection plate and move the throttle checking to see the rack is moving. Note refernence #21 on this parts drawing. Yanmar Tractor Parts: INJECTOR_PUMP
/ yanmar ym2000
i have had the pump out and this part would not move, should i be able to move it by hand?
/ yanmar ym2000
It should drop of it's own weight, end-to-end just by tilting the pump.
I believe that you have identified the problem. It does not move. What could have made it stick. The inside of the pump looks new. I can take a drift punch and the handle of a screwdriver and it will move. I have sprayed id down with WD40 with no results. Any suggestions
/ yanmar ym2000 #6
Time and rust made it stick. If continued working it with lubricants applied does not work then nothing left but to take it apart. They are a bit complicated and if you don't feel confident you might want to consider and injector pump shop. You do not want to change any settings on the internals.
Here is what a new one is worth. Yanmar Tractor Parts INJECTOR PUMP - NEW! - OUT OF STOCK - WE CAN REBUILD YOURS Well, looks like they are out of stock, might want to inquire about the rebuild.
Any knowledge of the condition of the tractor before being set up?
/ yanmar ym2000
Thanks I have taken it down as far as it will come with the drive pins in. It looks like that one of the center rods (I assume that this is the volume adjuster) is rusted or gummy.
/ yanmar ym2000 #8
Unless you are a good mechanic I recommend having it rebuilt. There are timing marks that seem to give a lot of guys fits on reassembly.
/ yanmar ym2000
I have gone as far as my abilities can take me. If it does not loosen up in the next day or 2 that is exactly what i will do.
thanks
/ yanmar ym2000 #10
Good plan.
99% of the stuff on these Yanmars is user-maintainable, designed that way, but overhauling an injector pump is simply best left to a specialist. There's calibration needed that you can't do without test equipment, and probably special tools needed too.
I was amused to find for overhauling injectors on these 70's designs, the manual specifies to scrape the orifice only with 'a wooden stick and mutton tallow'. How's that for Old School. :D
I just figured after 35 years service I would replace with new instead of searching for mutton tallow. Then what I received was NOS in 70's packaging. (faded lime green, not red). So, Old School anyway.
/ yanmar ym2000 #11
Good plan.
HAHA thats great California!!!
/ yanmar ym2000
I have been using PB Blaster and WD40. is has loosened up but is still very stiff
Thanks Curtis
/ yanmar ym2000 #14
I have used pb blaster & wd40 too, but there is no comparison to kroil! I won't ever be without it again. it will soak into 1 millionth of an inch.
/ yanmar ym2000 #15
+1 for Kroll... I buy it by the gallon... Good stuff...
/ yanmar ym2000
i just ordered 2 cans of Kroil. I could not find any locally. will give it a try along with a prayer.
/ yanmar ym2000 #17
I would have more faith in the prayer. :thumbsup:
/ yanmar ym2000
I had it soaking all day in PB Blaster. I rinsed it with an industrial degreaser, kept working and the rack suddenly freed up. I still think i have problem internally. Does any one have a breakdown with part names?
/ yanmar ym2000 #19
Here is out of the 240 parts manual, I think the same as your 2000.
/ yanmar ym2000
thanks Winston1. I doubt if i take it apart but at least i can call the parts by their proper name.
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
NEW Wolverine 72" Skid Steer Bucket, 38" Depth (A62679)
NEW Wolverine 72"...
2015 Kawasaki Prairie 400 ATV (A64557)
2015 Kawasaki...
2022 EZ-GO ELITE...
2018 CATERPILLAR 573D FELLER BUNCHER (A65053)
2018 CATERPILLAR...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
