Build it yourself? How about "Machine it yourself"?
/ Build it yourself? How about "Machine it yourself"? #1
PHPaul
Downeast Maine
Kubota B2650 with cab, Pasquali 986
I posted in another forum about the Jari sicklebar mower I bought. The keyway on the main driveshaft is all hogged out and the drive pulley won't stay on.
Not a huge technical challenge for a machinist to weld up the keyway and cut a new one. Problem is, I don't have a mill to do it myself and I'm too cheap/impatient to drop it off at a machine shop and wait who knows how long for them to get around to it.
So, in the tradition of redneck mechanics everywhere, I cobbled up a way to do it on my drill press:
A regular vise mounted to an inexpensive (Grizzly) cross feed table. Clamp the shaft stock in the vise, use the table height adjustment on the drill press to center the stock on the cutter. Control depth with the Y axis on the cross feed and feed the stock into the cutter with the X axis. Belts on the press set for highest quill speed, obviously.
Several well-oiled shallow cuts later, voila! A new keyway.
Perfect? Not even close. Good enough for the girls I go with? Absolutely. It's a low speed application and works just fine. There are a number of things I'll do differently setup and adjustment-wise for better results next time, but this got me back to cutting brush for now.
Of course, the Kraut in me has ordered a new shaft from Jari to really fix it. $147 with shipping which sort of made me gasp, but when I looked up the price for the pulley (the bore is badly worn on the original) I darn near passed out: $125 plus shipping for a simple half-inch bore keyed 6" pulley for an "A" section belt!
Surplus Center, here I come...
/ Build it yourself? How about "Machine it yourself"? #2
Excellent! Thanks for sharing.
/ Build it yourself? How about "Machine it yourself"? #3
Looks good! As a guy that owns a machine shop, we wouldn't have done anything different (other than use a little more robust machine).
Thanks!
I used to work at a cannery as the Assistant Maintenance Manager and General Dogsbody. Years ago, before multiple sales and consolidations, the plant used to be entirely self-sufficient with a fully equipped machine shop and 4 tool and die men.
By the time I came along, we were down to an ancient Hendy lathe and a Bridgeport mill. Nobody left in the place that knew how to run them or cared. I wasn't long teaching myself a little basic machining, making small brackets and motor mounts, boring pulleys, milling slots and such.
The equipment is still there but the company closed down completely and the plant has changed hands twice in the last 5 years. I don't know anybody there any more. Sure would like to make off with that equipment but I have no place to put it and no 3 phase power.
/ Build it yourself? How about "Machine it yourself"? #5
glad it worked out for you. Nice to fix it your self.
FYI the reason that milling isn't done on a drill press more often, is that the drill chuck is held on with a taper mount. Works fine for axial loads, but can come loose with a side load.
/ Build it yourself? How about "Machine it yourself"? #6
The taper is not a deal breaker lots of mills use tapers but they also have a positive way to lock the male taper into the female, that most drill presses do not have.
/ Build it yourself? How about "Machine it yourself"? #7
That's what I was trying to say.
On the drill press, the taper alone is holding the chuck in. No drawbar, like on a mill or lathe.
/ Build it yourself? How about "Machine it yourself"? #8
I keep telling my wife I need a mill. She, being a female, keeps asking why. I haven't really come up with a good answer other than if I had a mill I could build and/or repair anything metal and it hasn't been good enough for her yet.
She is on board with the CNC plasma table though, once we get the shop built and move onto our land. But that can be used to make her "pretty stuff" so it was an easier sell.
/ Build it yourself? How about "Machine it yourself"? #9
I have a mill. It has a taper, but it has a bolt in from the top and a keyway to keep it from slipping.
/ Build it yourself? How about "Machine it yourself"? #10
STx tell your bride that tools are to men as shoes are to women. Maybe she can then understand.
/ Build it yourself? How about "Machine it yourself"? #12
Nice work!
/ Build it yourself? How about "Machine it yourself"? #13
My Floor model craftsman uses a M2 taper and not the smaller Jacobs taper. Its a little more robust and have used it to mill some slotted bolt holes. You can also buy taper attachments that accept most end mills, Jacobs and Mtaper ,but I havent tried any of them. And of course you can buy adapters to go from Mtaper to Mtaper and Jacobs to Jacobs, and M taper to jacobs taper. My chuck is 3/4" so I just chuck everything. I also use a M2 to M4 adapter to use my drill chuck on my lathe. I think as long as its manual feed and you resist the temptation to get in a hurry, you can do a lot with a drill press.
/ Build it yourself? How about "Machine it yourself"? #15
Nice working with what you have.
Do you have a lathe? Or did you just grind it "close enough" after welding?
Only thing I would have done different (and I've repaired many keyways and bores) would have been to cut the key in a virgin section of the shaft instead of over the weld. Only time I'll mill over the weld if it is something that has to be kept in time with the other end of the shaft
I did cut the new keyway opposite of the original. Sorry, didn't make that clear.
No lathe (yet...) so I eyeballed it with a flap disk in a grinder.
/ Build it yourself? How about "Machine it yourself"? #17
I see. Hard to tell from the pic but it looked like it was cut over the weld.
/ Build it yourself? How about "Machine it yourself"? #18
Every once in a while I need a milling machine for repairs. For as little as I use it, I didn't want to get a big or expensive machine. And I did not want to get an imported machine. Found this for $300 on Craigslist. Benchmaster, made in Los Angeles after WWII. This one is over 65 years old, still works fine.
NICE! That'd be just the ticket for my little shop. I'll have to start cruising Craigslist again.
/ Build it yourself? How about "Machine it yourself"? #20
I've been watching CL for a few years, I've never seen a deal like that. I'd be all over it if I did. I always see stuff like this - GRIZZLY G0704 CNC MILL.
Kubota 60in. Zero Turn Commercial Mower (A66734)
Kubota 60in. Zero...
2018 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A66736)
2018 Chevrolet...
2016 KEYSTONE 5th WHEEL (A67714)
2016 KEYSTONE 5th...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
2016 Autocar ACX Xpeditor T/A New Way 31ASL 31Yd. Side Loader Garbage Truck (A66736)
2016 Autocar ACX...
2005 Infiniti FX35 AWD SUV (A66738)
2005 Infiniti FX35...
