Oil & Fuel HST oil level
/ HST oil level #21
Check your breather tube. On the Grand L's it is in the filler cap. That may well be plugged causing your double dip problem as it is not lettig off pressure as needed.
/ HST oil level #22
This happens with my B3300, nothing on the stick then you put back in then it registers. I thought it had lost all my fluid first time I checked it.
/ HST oil level #23
I'm a double dipper, hot or cold.
Me too. Learned that when I was about 6 years old. Didn't know why then but it's been habit ever since. A vacuum or slosh can give you a false reading. Wipe and check is what my dad said. And look and smell your rag after wiping. Still not sure what the rag tells me but I do it out of respect for my father.
/ HST oil level #24
Namesray
The case gets pressurized and compresses the oil so the level appears lower until you pull the stick.
I would like to subscribe to your Oil-Is-A-Compressible-Fluid newsletter.
Your ideas are intriguing and I would like to know more about this discovery.
wrooster
/ HST oil level #25
wrooster
wrooster... funny. For those in the know or even care about the semantics here, hydraulic fluid is generally not compressible. If it was, the cylinder would not be very efficient in transferring power. I am pretty sure Namesray is not trying to redefine fluid dynamics science! :laughing:
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
Valley Model 8000 Irrigation System (A62180)
Valley Model 8000...
2018 International DuraStar 4300 26ft. Box Truck (A61573)
2018 International...
1984 Cab Over K100 Big Cam 350 (A62613)
1984 Cab Over K100...
2007 Chevrolet Silverado\ Silverado Classic Pickup Truck, VIN # 1GCEK14X27Z181945 (A61165)
2007 Chevrolet...
