iMatch/Quick Hitch Questions
/ iMatch/Quick Hitch Questions #1
Jsandy
Member
Georgetown, De
John Deere 4710
I used my iMatch on my JD 4710 for nearly 11 years with no issues. I took delivery of a 4066r this week and went to hook up my new Woods BB720X Rotary Cutter (never used on the 4710 or the imatch) and couldn't get it on to save my life. It seems that the imatch is too short (old non adjustable model) When the bottom hooks engaged the pins, the top hook was 2 1/2" to 3 " lower than the top link. The imatch measures approximately 15 1/2" from the bottom of the bottom hook to the bottom of the top hook. On the rotary cutter it is about 17 1/2 or 18" from the bottom of the bottom pins to the bottom of the top link. I changed the top link attachment point on the tractor and adjusted the top link in and out but I couldn't get the top hook on the imatch anywhere near the top attachment point on the rotary cutter.
It appears that I have to use some sort of quick hitch because the clevis pins on the bottom of the rotary cutter look to be category 2 and the 4066r is a category 1. The woods manual says that it is compatible with both Cat 1 and Cat 2 Quick Hitches. Am I doing something wrong or do I have to buy an adjustable imatch/Quick Hitch? I've seen both the Speeco and JD adjustables and neither seemed to be the quality of my 11 year old non adjustable iMatch. Any help or recommendations is appreciated. Thanks.
/ iMatch/Quick Hitch Questions #2
Hopefully these diagrams/specifications will help below:
You may need to use a top link extender:
/ iMatch/Quick Hitch Questions #3
I bought a used Woods BB48 rotary cutter. It was set up for conventional 3pt hitch. The hitch had to be assembled in a different way to use a quick hitch. And there were about 3 wrong ways to assemble the parts. I downloaded a manual to find the right way, then made and bought some missing parts. Works fine now.
You can download the manual here, to see if your hitch is correctly assembled.
Rotary Cutters
Bruce
/ iMatch/Quick Hitch Questions #4
Good link by bcp^^^
Hope you get this worked out and would add to keep the older IMatch and make everything fit it. To be "quick" you don't want to have to alter settings on any of the implements each time you decide to use them.
It has been an incredibly frustrating day. The Woods manual sux!!! After looking at the diagrams listed above and measuring again I find the iMatch is just a hair over 14.75" (right where it should be). As the dealer put the Woods mower together it appears configured for a Cat 2 machine Quick hitch. There are 3 holes in the yoke at the top of the mast and according to the manual and schematic, the attachment point for the top hook on the QH is a sleeved 5/8" grade 5 bolt in the 2nd hole. The manual doesn't show it but there are 3 holes in the mast. The lowest hole is is a 5/8" hole (too small for a Cat 1 7/8" pin). Because the schematic showed that the attachment point was a 5/8" sleeved bolt I attempted to remove the bolt that the dealer mounted in the 2nd hole to move it to the lower hole.. They must employ gorillas because nothing that I did could get the bolt off that nut. I tried hitting it, used a "cheater" and fired up the pneumatic impact wrench, all w/o success. Having given up on budging the attachment point, I found a 5/8" hitch pin and put it through the lowest hole. That put me close to the right measurements but when I hooked the iMatch up, the bottom pins were not making full contact with the bottom hooks. I had a couple of CAT 2 to Cat 3 bushings that I slipped on the bottom pins and every seemed to line up.
I still don't like not getting the sleeved bolt apart. I don't think that the Masts line up. Everything needs to be loosened and realigned. Short of putting heat to the nut are there any suggestions. Everything feels jury rigged.
/ iMatch/Quick Hitch Questions #7
A picture might help us help you.
From what I read in your post I should clarify that 3/4" is the correct top link size for a cat 1 hitch, 7/8" is the correct size for the lower links cat 1 hitch. If it were me and everything else fits correctly except the 5/8" bolt size I would drill it out to 3/4" and use a standard 3/4" top link pin. Add the 1 to 2 and 2 to 3 bushings to get to the cat 3 size.
The other choice is to weld in a piece of cat 3 top link pin properly centered in place of the 5/8" bolt. I have used this method on a few implements that needed the extra strength in the design. If you do this make sure everything is in alignment first as it will be frozen in place so to speak.
/ iMatch/Quick Hitch Questions #8
I have a Woods BB720X. From the factory it fit right on a SpeeCo CAT2 quick hitch, which means it is too high without adjustment to fit a CAT 1 quick hitch.
Check the owners manual for the proper Cat 1 set up.
Eric, thanks for the response. At this point I think I'm going to load it up and take it back to the dealer and tell them to use whatever air gun they put it together with and loosen everything. The nuts for adjusting the height of the tail wheel are so tight that you can't even adjust the height of the cut. You sure as heck don't want your mower to come apart in the field but this is ridiculous.
/ iMatch/Quick Hitch Questions #10
Jsandy,
If it isn't much trouble I agree, let the dealer who sold it to you make it fit and work properly.
/ iMatch/Quick Hitch Questions #11
If I recall right, every fastener is a 15/16th locking style that has a lot of drag torque.
Before you load up the cutter, make sure you can loosen the bolts and nuts to adjust the trailing wheel as you may want to change the rear ride height.
They are 15/16 with a lock nut that I haven't seen before. Working on it this afternoon I got one nut loose that adjust the rear wheel. Is there a trick to loosening this locking style nut? I don't think that the masts are aligned with one another and I still want to move the attachment point down to the third hole instead of just relying on a 5/8" hitch pin that doesn't ride well in the bottom of the big (by comparison) top hook of the Cat 1 imatch.
/ iMatch/Quick Hitch Questions #13
My technique is being a Swede, and younger too. 😀
The staked nuts are a PITA to do by hand but I did it with a pair of combination wrenches. At 46 years old, age may be on my side.
For what it is worth, I did take a picture of my CAT2 quick hitch set-up today.
You have your top link where mine needs to go. Right now it is in the hole above and I am "making do with a 5/8" hitch pin. Are your lower bushings "pinned". I assume they are Cat2 to Cat3 bushings? I had a box end wrench on with a piece of 4ft 2" steel pipe as a cheater and the only movement I got was feeling the box end wrench start to bend.
/ iMatch/Quick Hitch Questions #15
One of my wrenches was a snap-on, while the other was a Northern tool. I wedged one wrench against the deck and leaned on the other wrench to break stuff loose.
My lower bushings are cat 2 to cat 3 but are not pinned.
General Guardian/Quiet Source Gen Set (A64912)
General...
2010 Dodge Ram 3500 (A64911)
2010 Dodge Ram...
2025 24in Bucket Mini Excavator Attachment (A66734)
2025 24in Bucket...
2009 HEIL CRUDE PUP TRAILER (A67714)
2009 HEIL CRUDE...
10' Fork Extension (A64912)
10' Fork Extension...
2023 Del Morino Funny 132M Hydraulic Flail Mower Attachment (A66734)
2023 Del Morino...
