Leaking front axle John Deere 4410
   / Leaking front axle John Deere 4410 #1
atomic41
Member
Troutville, VA
John Deere 4410
Hey guys! Brand new to site. 500 hours. Just noticed a pretty bad leak. Replace seal or other fix?
   / Leaking front axle John Deere 4410 #2
Hi and welcome to the forum! :welcome:
I'm going to move your thread over to the John Deere section to see if we can get you some answers.
   / Leaking front axle John Deere 4410 #3
can you post pics of where its leaking? that helps a lot
   / Leaking front axle John Deere 4410 #4
atomic
:welcome: to TBN
Below this thread, there are some hits of other threads covering the leaking seal.
As some others do, I just crack the dip-stick plug on the axle so when the oil heats up from use then the axle can vent and doesn't leak at the seal or leaks less.
I understand they are not difficult to change out, but I'm thinking if not vented then the new one will leak after a short time too.
Thank you all for the reply. I need to change the axle oil anyway. I'll just make sure to loosen the dipstick!
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A55973)
2022 Ford F-250 XL...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
Hydraulic Floor Jack (A59076)
Hydraulic Floor...
2007 International 4200 Homemade S/A Chipper Truck (A56858)
2007 International...
New/Unused Double Stall Portable Toilet (A57453)
New/Unused Double...
