Another ballast box 1000lbs
/ Another ballast box 1000lbs #1
Luke'sScreenName
Elite Member
Lakes Region, NH
Kubota MX4800 with BH-90X hoe; Hustler FastTrack 48; B3300SU (sold); 1969 Case 680B CK (sold)
Finished off a quick and dirty ballast box today. Plywood form, rebar, and 1000lbs of concrete Quickrete. Used a 3pth tow bar for lift pins and welded up some angle iron I had laying around for the top link.
4inch PVC with a drain hole in the bottom for long handled tools. 2" square tube hitch receiver.
I also used a plastic chainsaw bar cover for a scabbard form. Then I threw together a box on top to hold stuff.
/ Another ballast box 1000lbs #3
And when you lower the 3pth you know the tractor will stay where you leave it....The saw scabbard is a great idea as well
/ Another ballast box 1000lbs #5
luke, do you have your tires loaded as well?
I like the what you have done there.
thanks,
dave
Yes, tires loaded with calcium. But when using my tree puller or my freaking heavy, 900lbs grapple, I need all that weight! I also have a 600lbs box but that wasn't enough.
/ Another ballast box 1000lbs #7
Shovel holder- check scabbard- check hitch- check tool tray- check only the beer cooler is missing. Probably intentionally!
/ Another ballast box 1000lbs #8
That is very nice I like the box on top too. The saw scabbard is genius so that give me more ideas....
/ Another ballast box 1000lbs #9
I'll give you $350 for it:laughing:
Look's nice Luke, and some smart features:thumbsup:
Ha. Ha. Not a bite at $250 on CL. :confused3: So be it.
/ Another ballast box 1000lbs #11
Luke, my wife wants me to build a fort... could she be talking about a doghouse? BTW... we don't have a dog. But hey... I take that as... go ahead build a shop extension to the garage so she can park inside. Sorry off topic.
Did someone say "shop extension?!"
2025 20in. Rotary Brush Cutter Mini Excavator Attachment (A66734)
2025 20in. Rotary...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
2012 PUMA BUMPER PULL (A67714)
2012 PUMA BUMPER...
2018 Ford Focus (A61574)
2018 Ford Focus...
2007 Mazda 3 Sedan (A66738)
2007 Mazda 3 Sedan...
2016 Mobility Ventures Van (A66738)
2016 Mobility...
