Chipper Woodmaxx vs Jinma chipper
/ Woodmaxx vs Jinma chipper #81
Put my Woodmaxx to work chipping maple branches left from trees I've recently dropped for firewood. Only my 2nd time using it - it's a beast! I love the hydraulic infeed! Sent from my iPhone using TractorByNet
/ Woodmaxx vs Jinma chipper #82
Howdy Folks,
I spent a good amount of time searching the forums for Woodmaxx Chippers. This one seems like it has the most info? Is there a better one?
I'm considering buying the Woodmaxx WM-8H. I would love to hear back from some of the guys who bought them back in 2011 when this thread was started. How are they holding up after 5 years?
Thanks
GOOBZ
/ Woodmaxx vs Jinma chipper #83
I bought my WM-8H in the spring of 2013 and it has performed flawlessly so far.
I spent a full day last year chipping huge piles of brush my neighbor had accumulated over the years.
This was very dry dusty wood but the Woodmaxx handled it with ease.
Cleat
/ Woodmaxx vs Jinma chipper #84
Thanx Cleat!
What's a guestimate of how many hours you've put on it?
How may times have you sharpened the blades?
How many PTO HP is your tractor?
What's your elevation?
Thank you in advance!
GOOBZ
Cleat
/ Woodmaxx vs Jinma chipper #85
What's a guestimate of how many hours you've put on it? I would say around 25 actual working hours
How may times have you sharpened the blades? None yet but they are reversible and I have a spare set.
How many PTO HP is your tractor? 30
Latitude: 44.69939 North
Longitude: 75.74799 West
Altitude: 122m/400ft
/ Woodmaxx vs Jinma chipper #86
I'm not sure if this is relevant for you or not but I have a farm pro 6 inch chipper. It usually gets the job done but not without a fair share of problems. I have had a lot of Feed wheel issues. Have had to rebuild the driveline that runs the feed wheel three times. Just recently had to change bearings. And I haven't even had to sharpen the blades yet. It was cheap so I guess I got what I paid for and like I said it does seem to get the job done. But it's definitely not professional quality. I think if you're looking for a chipper and you're considering a Chinese brand my advice would be to make sure you're comfortable working on it from time to time.
/ Woodmaxx vs Jinma chipper #87
That is why I bought the hydraulic infeed unit.
Seems to be too many problems with the mechanical infeed.
If the pump causes any grief I can always just use the tractors hydraulics to run it.
Cleat
/ Woodmaxx vs Jinma chipper #88
I got the WM-8M two days ago and got to use it yesterday. I debated whether I should get the hydraulic feed model but decided on the manual based on your feedbacks. I chip about 95% pine/fir and feed only up to 5-6" stuff and so far, I'm quite pleased with it. If Woodmaxx made a fold-up chute to save space, that would be the bomb but I can deal with it.
I do plan to install rounded corners on the bottom & sides as branches likes to snag on them. Probably will install a chainsaw scabbard & holder for a pair of loppers. Those two tools are a must for me and would like it to be easily accessible.
Anybody have any thoughts about why Woodmaxx is offering two choices of PTO shafts (Standard vs American)? I went with the standard and it did fine. Any difference between the two?
Meanwhile, this chipper will now be regulated to light duty to tow around my property with my ATV. Nice little brute that can chip up to 4" wet pine.
/ Woodmaxx vs Jinma chipper #89
Howdy Folks,
Thanks
GOOBZ
I've had my WM-8H for a couple years now. I have easily 25-30 hours on the unit. I have 60% pine, 45% maple and 5% miscellaneous trees and woody vines. Pine feeds like a dream through it. Maple does better if it dries for a few months first. It will feed maple when green, but anything bigger than 4 inches and it tends to bog down. Also, keep all side branches of an inch or more very short BECAUSE if they stick out through the slots where the auto feeder pivots up and down, it will jam up and can be very tedious to unjam.
I'm running mine on a 48 HP at the PTO Workmaster 55.
From a financial standpoint, the 4th or 5th time I ran it, it paid for itself (compared to renting a 6 inch or God forbid 12 inch chipper).
/ Woodmaxx vs Jinma chipper #90
Following the arrival of notices about the last few posts I went on their web site this morning to check out the prices.
SURPRISE ! There is now a 9900 model, and a 9900SS (for skid steer) as I expected, bigger, supposedly better and of course more MONEEeeeeeee.
It seems to reach diminishing returns fairly quickly, the 8M $2280 8H $2800 MX9900 $5,000-10 then the MX9900SS at $8500
The 8M and 8H look to be MUCH fairer deals now :D
/ Woodmaxx vs Jinma chipper #91
I posted a nice review on the Woodmaxx website, last year, about the WM-8H. I have about thirty running hours on the machine now. I am really glad I bought it."I would say if you want one, go get one".
/ Woodmaxx vs Jinma chipper #92
I purchased a WoodMaxx 8H PTO powered unit with import drive shaft. I attached it to my LS Tractor G3033H, (PTO HP 26) all I needed to do was trim the drive shaft 2.75 inches. After a few hours of chipping pine rp to 5 in. diameter, as I went to re-start and engage the PTO drive, I had the engine RPMs at 900, which apparently is too high for the import drive shaft's shear bolt!
WoodMaxx's on line parts web page doesn't list these shear bolts, so I'll be taking the broke bolt with me to the hardware store, but I was wondering if anyone knew of a replacement shear bolt by part number? I'm retired USAF aircraft maintainer, and I'm conditioned to replace things per the technical order, so I get a bit anxious when it comes to guessing if a non-listed part will do!
/ Woodmaxx vs Jinma chipper #93
That had to be a really crappy bolt to let go at 900 RPM on the 26 PTO HP tractor!
I'd give Woodmaxx a call on this. It might save others from suffering the same type failure you experienced.
/ Woodmaxx vs Jinma chipper #94
I purchased a WoodMaxx 8H PTO powered unit with import drive shaft. I attached it to my LS Tractor G3033H, (PTO HP 26) all I needed to do was trim the drive shaft 2.75 inches. After a few hours of chipping pine rp to 5 in. diameter, as I went to re-start and engage the PTO drive, I had the engine RPMs at 900, which apparently is too high for the import drive shaft's shear bolt! WoodMaxx's on line parts web page doesn't list these shear bolts, so I'll be taking the broke bolt with me to the hardware store, but I was wondering if anyone knew of a replacement shear bolt by part number? I'm retired USAF aircraft maintainer, and I'm conditioned to replace things per the technical order, so I get a bit anxious when it comes to guessing if a non-listed part will do!
Grade 3 bolts work well
/ Woodmaxx vs Jinma chipper #95
Page 18 of my manual says ... "Shear Bolt Replacement - Grade 2, Size 5/16 x 18 x 2”. I have a WM-8H model.
/ Woodmaxx vs Jinma chipper #96
Has anyone felt the need to reverse the bolts protruding into the hopper? I would think some button heads would let things flow better. Has anyone done it, or even considered it?
/ Woodmaxx vs Jinma chipper #97
I thought about it but decided to wait & see after running through its paces. So far, it hasn't been a real hindrance. The branches catching the edges of the chute was far more annoying
/ Woodmaxx vs Jinma chipper #98
That's been my experience too.....
/ Woodmaxx vs Jinma chipper #99
Seems like plenty of satisfied WM-8 users without a regret...
/ Woodmaxx vs Jinma chipper #100
None for me. The cost difference on what I saved, I can use towards other implements.
2025 Pabreak 6-Way 84in. Serrated Hydraulic Dozer Blade Skid Steer Attachment (A61567)
2025 Pabreak 6-Way...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
PREVIEW DATES AND TIMES (A61165)
PREVIEW DATES AND...
2005 Chevrolet C4500 Altec Bucket Truck (A56858)
2005 Chevrolet...
2006 John Deere 120C Hydraulic Excavator (A56857)
2006 John Deere...
