2015 BX25D - plans for "upgrades"
/ 2015 BX25D - plans for "upgrades"
OK here it is - the "no-weld" skid plate.
I used 2" angle iron, some 3/16" x 3" steel, a bit of 3/16" x 2" steel , 2 1/2"-13 grade 8 bolts with jam nuts and regular nuts, a piece if 1/16" sheet steel and a lot of 1/4-20 bolts, nuts and washers. If any one is interested I'll post the drawings with dimensions at some point. It's not the design I originally had, but after crawling around under the beast, I realized that attaching it to the mower arms was the right thing to do. The secret was making the front brackets that attach to the 1/2" bolts installed in an existing hole in the frame. Once I figured that out the rest was just a matter of figuring out what materials I had on hand and how I would use them. It goes on fairly easy and is solid once it's up. The 3/16" steel provides protection for the filter and PTO. The sheet steel covers the existing "guard" as well as the wires up front. I could add another front piece if it seems necessary, but for now this will work. I'll paint it later but need to get some projects finished! The long 1/4 bolts will all get cut off after I get the painting done. I was in the midst of moving some brush when I heard the dreaded bbrrrrrrrrt sound of a stick hitting the fan! I immediately shut down and took a look. No damage but the was a mark on the fan made by a fresh cut pine branch...lucky! So I put the tractor in the shed, and worked on the plate until done! Here are pics of the plate and my shed/shop.
CIMG1818.jpgCIMG1830.jpgCIMG1829.jpgCIMG1827.jpgCIMG1826.jpgCIMG1825.jpgCIMG1824.jpgCIMG1823.jpgCIMG1820.jpgCIMG1831.jpg
Step Hitch - rainy day here so I spent a few minutes being creative with my die grinder. :D
Have not tested this yet, but it's going to be used with a light utility trailer for brush and the occasional stump. I know I know, it's not the right place for a hitch, but I figure the weight that the ball hitch will see probably won't exceed 200 lbs., and if the tractor isn't tipping over when I step on it, :eek: it should be OK. :thumbsup:
I took a standard 2" hitch ball and ground notches to fit the "bumps" in the step. Then put a 3/4" washer and lock on the bottom...voila!
/ 2015 BX25D - plans for "upgrades" #23
Step Hitch - rainy day here so I spent a few minutes being creative with my die grinder. :D Have not tested this yet, but it's going to be used with a light utility trailer for brush and the occasional stump. I know I know, it's not the right place for a hitch, but I figure the weight that the ball hitch will see probably won't exceed 200 lbs., and if the tractor isn't tipping over when I step on it, :eek: it should be OK. :thumbsup: I took a standard 2" hitch ball and ground notches to fit the "bumps" in the step. Then put a 3/4" washer and lock on the bottom...voila! <img src="http://www.tractorbynet.com/forums/files/customization/430740-2015-bx25d-plans-upgrades-0623151006-jpg"/><img src="http://www.tractorbynet.com/forums/files/customization/430741-2015-bx25d-plans-upgrades-0623151007-jpg"/>
Pretty slick.
Yeah it look "cool" but it failed :mad:...when I backed the trailer up without a load, the step started to bend! :eek: I could reinforce it with some angle iron but I think I'll write this one up as a lesson learned. :cool:
/ 2015 BX25D - plans for "upgrades" #25
Ah too bad... obviously can't stand much of a lateral load compared to vertical. I'm a continent away from mine to look at the 'structure' but maybe some kind of gusset if you are still serious about making a go of it but likely you need to pick a more stout area to start with. Good luck.
/ 2015 BX25D - plans for "upgrades" #26
Thanks for sharing (a la Paul Harvey) the rest of the story. Most folks won't share a failure. But, more is learned from a failure than most will admit, or can imagine. Thanks again.
Chain Saw Scabbard - completed!
Bolted to the left floor where there are two holes for bolts that hold the deck. Then a couple of pieces of angle iron, and some wood that fits inside the iron, one additional bracket to hold it all tight.
I resized the pics...I can see them fine..try it now?
It's amazing how time fly's when you have a BX25D! Just did my 50 hour service. Review TBN and John's advise first then got it done! The only difficult part was having to remove the factory HST fan guard to get the HST filter off. I didn't remove it when I put my own skid plate on but now that it's off it will stay off!
Skid plate is working well and seems to be protecting everything under there. I've really abused this machine but it "takes a lickin' and keeps on tickin'"! :cool2:
Got the first tool box all mounted up. I found that Tractor Supply had two ammo boxes (30 cal and 50 cal) for $29.95 so I pick them up. Had some plastic type material left from another project that made perfect spacers for the brush guard mount. So when I took the brush guard off to do the 50 hr maintenance I made up the mount before I put it back on. Here's the 30 cal box mounted to the guard. Haven't decided where I'll mount the 50 cal box yet...
/ 2015 BX25D - plans for "upgrades" #33
Nice work. Are those boxes for sale currently at TSC? $10/each?
Thanks for the idea. Been looking for tool box mounting ideas and options for the BX25 and this is a great start. Just ordered the ammo box combo online from TSC. Can't wait to see what you come up with for the 50 cal box so I can copy that too! This should work good for my chain and maybe a couple other misc items.
Be sure you mount it high enough so you have clearance between the box and the FEL cross member/stand! :eek:
I'm working on an idea for the 50 cal to be able to mount on the FEL brace but I want it to be an easy on/easy off type mount. Maybe some type of slide mount? :rolleyes:
0914151120.jpgBucket Forks - not on my original list but realized I needed them so...
I looked in the scrap steel pile and found a couple of fifth wheel mounts for a pickup bed. They are about 4 ft long and real sturdy so I got some chain, chain binders, 3" u-bolts I had, a couple of 40" 2 x 6 and some carriage bolts...voila! Bucket forks! (Thanks to the folks on TBN that gave me the ideas for this!)
Well it's been almost exactly 2 years since I got the BX25D. Still amazed at how much work that thing can do. Just turned 200 hours on it and I realized I put nearly 100 hours on it last winter alone! Lot's of snow here! :)I think I've posted all the changes I've done except the increase in hydraulic pressure...added a .04 shim and it's just about right now. I also just got my 60" MMM and turf tires. That thing really cuts some grass! I've started on the field next door and got a lot done just messing around for 1/2 hour. :thumbsup:I'm mowing in high range and running at about 3000 RPM. I do have to watch closely for rocks! :eek:I'm marking them so I can come back with the backhoe and remove them....or bury them. :thumbsup: I took the FEl off for the first time and that was an interesting experience. Just took my time and followed the instructions in the manual. :) Oh yeah I also made a dolly for the backhoe. Only took about a half hour using a couple of furniture dollies and some scrap 2x10 pieces I had laying around. Didn't have to cut anything. I'll post pictures when I get a chance.
Looking forward to a summer of fun on the "beast: again. My neighbor wants me to do some additional grading on his drive and parking lot this summer. That's always fun too!
Hope everyone has as much fun as I do! :drink:
Wolverine 84" Quick Attach Snow Push (A66285)
Wolverine 84"...
2020 VOLVO EC140EL EXCAVATOR (A65053)
2020 VOLVO EC140EL...
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A61573)
2013 Ford F-550...
JOHN DEERE 310 - 16' DISC HARROW (A64276)
JOHN DEERE 310 -...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A59823)
2017 FORD F-350 XL...
