Best MIG for a $1000
/ Best MIG for a $1000 #1
Chain Bender
Kubota L3200
Not a pro and won't be used commercially. Just to piddle around the shop, maybe build a few aluminum ladder stands etc. Retired and have to much spare time on my hands. Is AC output a requirement for good welds or nice to have? What about the HF and pulse stuff. See, I'm new to aluminum.
tks in advance for any suggestions,
Chain Bender
/ Best MIG for a $1000 #2
Are you talking Mig or Tig? No HF or AC output with Mig.
/ Best MIG for a $1000 #3
If it were me. Lincoln 120mp.
I'm seriously eyeing one myself. Mig, stick, tig, 120 or 220
MIG. I thought I previously read a thread on here that condemned the Harbor Freight and Northern MIGs because they wouldn't do AC.
But just basically want something that will weld 1/8th aluminum strong enough that 240# won't break it loose.
/ Best MIG for a $1000 #5
No, the condemnation was because they harbor freight Migs do put out AC, but they should not.
So I had my outputs BASSACKWARDS then. OK, tks.
I do like the first glance at the Lincoln MP210, but it doesn't come with a spool gun. Add another $300 plus to the tab.
/ Best MIG for a $1000 #8
To weld aluminum you need a spool gun, and that will eat up most of your budget. All of the welder in my shop were bought at auction sales. If you have 220 volt power I wouldn't waste time with 110 volt models.
/ Best MIG for a $1000 #10
110 volt models.
You can use a MIG welder without a spool gun. I have been most successful with 5356 0.035" wire with
my Hobart Ironman 210. It is stiffer than 4043 and much less likely to "rats nest" at the drive roller. I have used
4043 at 0.030", and do not recommend it. One of the tricks to use Al is to use a larger tip and stick with
big wire: .040 tip and .035 wire. A spool gun IS made for the Hobart, but I am too cheap to buy it.
That said, MIG welding with aluminum this way is not for fine work.
There is a place for 120V MIG welders, too. Better portability, for one. They work fine for thinner metal,
in my experience.
/ Best MIG for a $1000 #11
When I first got my Lincoln V350-Pro with spool gun. I was playing with it to see what it could do. And record the settings. This is 16-GA aluminum. I got it welded, but I would much rather do this kind of work with Tig.
/ Best MIG for a $1000 #12
The spool gun for my TA 181i was under $300 whereas the Miller 30A with Wc24 controller for my other TA and Miller was close to $1500 MSRP.
Terry
/ Best MIG for a $1000 #14
Here's a 1/8" mig weld. Can't even remember which spool gun or welder, so please don't ask me to recall the settings. Getting old sucks. I should think to document things like Shield Arc.
Terry
/ Best MIG for a $1000 #15
WOW! That is a very nice Mig weld on aluminum Terry! :thumbsup::thumbsup:
/ Best MIG for a $1000 #16
Thanks, SA, fortunately for me, as mentioned my iPhone ap won't allow me to post the other crappier looking welds. :)
Terry
/ Best MIG for a $1000 #17
Thanks, SA, fortunately for me, as mentioned my iPhone ap won't allow me to post the other crappier looking welds. :) Terry
Same issue here! Post your sentence and 1 photo then edit add photo post repeat till all your pictures are on!
PITA I know but works
Sent from my iPhone 5s 64Gb using TractorByNet
/ Best MIG for a $1000 #19
Same issue here! Post your sentence and 1 photo then edit add photo post repeat till all your pictures are on! PITA I know but works Sent from my iPhone 5s 64Gb using TractorByNet
Hey thanks, Eric! Now I need to figure out why the app on the iPad mini tells me to 'log in' and when I try the screen goes complete black. :(
Terry
/ Best MIG for a $1000 #20
We all make them, no need in posting pictures! :D
My daughter once pointed out to me that it was a good thing I didnt make too many 'perfect' welds as I'd waste too much time admiring them. :(
Terry
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2018 Jayco JayFlight 264BH (A62613)
2018 Jayco...
2016 Isuzu NRR 18ft. Flatbed Truck (A61568)
2016 Isuzu NRR...
2013 FORD F-250 (A60736)
2013 FORD F-250...
1995 Kawasaki Bayou 300 4x2 ATV (A60352)
1995 Kawasaki...
2008 FORD LOW CAB FORWARD (A59908)
2008 FORD LOW CAB...
