Best MIG for a $1000
/ Best MIG for a $1000 #1
Chain Bender
Kubota L3200
Not a pro and won't be used commercially. Just to piddle around the shop, maybe build a few aluminum ladder stands etc. Retired and have to much spare time on my hands. Is AC output a requirement for good welds or nice to have? What about the HF and pulse stuff. See, I'm new to aluminum.
tks in advance for any suggestions,
Chain Bender
/ Best MIG for a $1000 #2
Are you talking Mig or Tig? No HF or AC output with Mig.
/ Best MIG for a $1000 #3
If it were me. Lincoln 120mp.
I'm seriously eyeing one myself. Mig, stick, tig, 120 or 220
MIG. I thought I previously read a thread on here that condemned the Harbor Freight and Northern MIGs because they wouldn't do AC.
But just basically want something that will weld 1/8th aluminum strong enough that 240# won't break it loose.
/ Best MIG for a $1000 #5
No, the condemnation was because they harbor freight Migs do put out AC, but they should not.
So I had my outputs BASSACKWARDS then. OK, tks.
I do like the first glance at the Lincoln MP210, but it doesn't come with a spool gun. Add another $300 plus to the tab.
/ Best MIG for a $1000 #8
To weld aluminum you need a spool gun, and that will eat up most of your budget. All of the welder in my shop were bought at auction sales. If you have 220 volt power I wouldn't waste time with 110 volt models.
/ Best MIG for a $1000 #10
110 volt models.
You can use a MIG welder without a spool gun. I have been most successful with 5356 0.035" wire with
my Hobart Ironman 210. It is stiffer than 4043 and much less likely to "rats nest" at the drive roller. I have used
4043 at 0.030", and do not recommend it. One of the tricks to use Al is to use a larger tip and stick with
big wire: .040 tip and .035 wire. A spool gun IS made for the Hobart, but I am too cheap to buy it.
That said, MIG welding with aluminum this way is not for fine work.
There is a place for 120V MIG welders, too. Better portability, for one. They work fine for thinner metal,
in my experience.
/ Best MIG for a $1000 #11
When I first got my Lincoln V350-Pro with spool gun. I was playing with it to see what it could do. And record the settings. This is 16-GA aluminum. I got it welded, but I would much rather do this kind of work with Tig.
/ Best MIG for a $1000 #12
The spool gun for my TA 181i was under $300 whereas the Miller 30A with Wc24 controller for my other TA and Miller was close to $1500 MSRP.
Terry
/ Best MIG for a $1000 #14
Here's a 1/8" mig weld. Can't even remember which spool gun or welder, so please don't ask me to recall the settings. Getting old sucks. I should think to document things like Shield Arc.
Terry
/ Best MIG for a $1000 #15
WOW! That is a very nice Mig weld on aluminum Terry! :thumbsup::thumbsup:
/ Best MIG for a $1000 #16
Thanks, SA, fortunately for me, as mentioned my iPhone ap won't allow me to post the other crappier looking welds. :)
Terry
/ Best MIG for a $1000 #17
Thanks, SA, fortunately for me, as mentioned my iPhone ap won't allow me to post the other crappier looking welds. :) Terry
Same issue here! Post your sentence and 1 photo then edit add photo post repeat till all your pictures are on!
PITA I know but works
Sent from my iPhone 5s 64Gb using TractorByNet
/ Best MIG for a $1000 #19
Same issue here! Post your sentence and 1 photo then edit add photo post repeat till all your pictures are on! PITA I know but works Sent from my iPhone 5s 64Gb using TractorByNet
Hey thanks, Eric! Now I need to figure out why the app on the iPad mini tells me to 'log in' and when I try the screen goes complete black. :(
Terry
/ Best MIG for a $1000 #20
We all make them, no need in posting pictures! :D
My daughter once pointed out to me that it was a good thing I didnt make too many 'perfect' welds as I'd waste too much time admiring them. :(
Terry
JOHN DEERE 6105E TRACTOR (A62130)
JOHN DEERE 6105E...
2012 Toyota Tundra SR5 Crew Cab Pickup Truck (A61568)
2012 Toyota Tundra...
Patterson water pump (A59230)
Patterson water...
2016 CATERPILLAR 416F2 BACKHOE (A62129)
2016 CATERPILLAR...
1999 Ford F-150 4x4 Pickup Truck (A61568)
1999 Ford F-150...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
