dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,802
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
After splitting the case, I first removed the motor (1st, 2nd photos). On first inspection, it
looked OK. The slippers looked smoother than I am used to seeing. Other HSTs
have pre-cut scratches in the slippers to help retain an oil film. I will check the
thickness with a micrometer later, after getting the spec from the manual.
I meant to report on the slippers, but I do not have a good close-up of the
pump slippers. I did mike them.
The manual has no spec on the slipper thickness, as I would expect, so I
just compared the thickness of those from the motor to those from the
pump.
They were the same. The pump slippers do have the pre-cut micro-scratches
that I expected to see on the motor slippers. This indicates to me that
none of the slippers had experienced significant wear.
Why the maker did not use micro-scratches on the motor slippers, I do not know.
