kubota L3540 cab
/ kubota L3540 cab #1
harold4
Bracebridge ont canada
l3540
Hello people i have just rolled my tractor on thursday onto the roof from a 20 ft drop and its pretty dammaged so i have to find another one the question is do they bolt on can they be replaced it is from the factory not a soft side it has the air heat stereo front rear wiper all controls for these are on the headliner now does anyone know what they are like to change if i can find one and yes the roll bars are all bent will have to be straightend or changed but the question is can i get one Harold Muskoka Ontario Canada
/ kubota L3540 cab #2
:welcome:
To TBN Harold. I sure hope that you didn't get hurt. Do you have pictures to post to help us not to go the same route? Were you able to get it right side up quickly? Have you tried starting it yet?
/ kubota L3540 cab #3
I don't believe the factory cab can be replaced without a major tear down of the tractor;I.E. you can't add a factory cab to an open station so you are looking at a major job probably done by a dealer.If your ROPS is bent that also will have to be replaced.
You may want to contact your insurance agent if you had insurance on the tractor;this could be very expensive.
Hope you weren't hurt.
/ kubota L3540 cab
I have attached photos below. I have not gotten it out yet or started it. 89m & 90 were put on in error. Please just ignore them. Thanks
Harold
/ kubota L3540 cab #5
Yes, the cab can be removed/replaced, the WSM gives details on this as it must be removed and the tractor split to replace seals etc., I have no idea of the cost, but I'm sure it's pretty high.
/ kubota L3540 cab
no insurance rops are bent and I got whiplash plus hurt my back but nothing broken it was a 20 ft fall I think, been told the highback seat saved me
/ kubota L3540 cab #7
I'm very sorry this happened to you, but it sure is a reminder to some of us who may be taking too many chances. We have a lot of drop-offs on our farms and I probably need to stay a bit further away from them.
/ kubota L3540 cab #9
thanks but I thought I was but the bank gave out
Yep, that's what I mean, my Rhino fell in with me close to ten feet from the edge several years ago. We also had one give away on one of our roads and the only indication was a very small hole, we checked it with the ATV then on foot and had to dig out and replace a big section. I need to go out and check some places and some. I've just abandoned and won't go near.
/ kubota L3540 cab #10
I have a brand new outer roof for that tractor I'd sell.
/ kubota L3540 cab #11
Glad you weren't hurt even worse as that looks bad even in pictures. Were you wearing your seatbelt?
Nice looking place you have there.
/ kubota L3540 cab #12
Glad you didn't get hurt too bad. Once you get it back on it's feet on solid ground don't try to start it. It'll most likely have oil that leaked past the piston rings and into the cylinder head. My suggestion would be check with your dealer and/ or to start a new thread to get an idea so you know what to check and do. No reason to any more damage. As for the cab, I would wait until you get it upright and can take a good inventory of just what damaged. Depending just how hard it is to get it out of there you might do some more damage.
/ kubota L3540 cab #14
Message me your email and tomorrow I'll send you a photo. Its easier to show a photo than to explain I guess.
/ kubota L3540 cab #17
So, why are you moving to Ar-Kansas? It is hot down here.
/ kubota L3540 cab #20
Good that you only had minor injuries- that could easily have been much worse, from the looks of it. Something you will never forget, I am sure! Keep us informed as you repair it, this is a pretty unusual job...
