Best chain lengths?
/ Best chain lengths? #1
jodebg
New Hartford, CT
Kubota B-2650
I have a 20 ft chain that I use for moving rocks, etc..
Most times it is too long.
I'm going to buy a second 20ft chain to cut into shorter lenghts.
Any advise on what lengths are good to use, and for using grab hooks and
slip hooks?
/ Best chain lengths? #2
Pretty much a unanswerable question as it depends on the job. Over the years I have found having multiple lenghts around is very handy. There is nothing more frustrating than having chain too short for a job or on the other hand one that is extra long that you have to contend with the excess length and weight for no reason. Having multiple lenghts at hand is money well spent in my opinion.
/ Best chain lengths? #3
8' + 12', grab hooks on one end of each, slip hooks on the other.
For a 'B' series Kubota Grade 70 X 1/4" is sufecient, although a little difficult to find. I last bought at Rural King @ $2.29/foot.
/ Best chain lengths? #4
Walmart has 12ft 1/4 inch grade 70 in the trailer hitch/tie down section around here. Plastic box about 5 inches square.
Bruce
/ Best chain lengths? #5
I usually buy 20' lengths of 5/16th" grade 70 chain and 2 extra grab hooks, then cut the 20' in half and put the grab hooks on to give me 4- 10'ers. That length works great for me for tying down on the trailer and lifting most items. I do keep a several extra 20'ers, a 30'er, and 10'ers. For smaller tie down items I use ratchet straps.
/ Best chain lengths? #6
/ Best chain lengths? #7
I prefer two 10' for general use, and a 20' for occasional "pull the car out of the ditch" times that happen.
/ Best chain lengths? #8
dang Kenny how often do you have to pull the car out:D
/ Best chain lengths? #9
I have been thinking about adding an extra hood on my 20ft chains I log with. Maybe 3 or 4 feet back. That would allow me to chain the log up closer for the times I have to snake around an obstacle.
/ Best chain lengths? #10
Big chains are good to have on hand. I have a couple of 25 footers that stay in a 5 gallon bucket so I know where they are. I have several others much much smaller from 4 to 12 foot that are hanging on the tractor or implements. I like to think of the big chains as special occasion weapons.....but I don't want to be dragging them big jokers around every day.
/ Best chain lengths? #11
If you can tie an improved clove hitch knot the extra length isn't a problem but is there when you need it and only 1 chain is needed.
/ Best chain lengths? #12
18" x 5/16" with grab hooks both ends gets used more than any other chain I have.
/ Best chain lengths? #15
Inch? Or did you mean Feet?
Inch, it works to lengthen or shorten either my 1/4" x 12' or 3/8" x 14' individually or in combination, it creates a loop to attach a clevis any where I want, it creates so much versatility, hands down the handiest piece in the chain selection.
Can the smaller lengths be safely joined to make a longer length? If so, how do I safely attach the
chains together?
I mostly lift and pull rocks. What is better to do this, a slip or grab hook?
Also, what do I need to buy for my tow bar for ataching a chain to it for pulling?
/ Best chain lengths? #17
chains together?
Grab Hook on one chain connected to a link on second chain.
You can cinch with a slip hook.
Tow bar or Draw bar? I would use a clevis attached 5/16" Grab Hook for your B7800, 3/8" Grab Hook for larger tractors.
/ Best chain lengths? #18
You would also like a 3-4 footer with or without hooks for pulling saplings and stumps.
/ Best chain lengths? #20
Chains slid off this rock like water off a duck. Estimated @ a ton, it took the jeep, trailer, come-a-long and one tired out square1 four hours to move about a mile ;)
If I ever do rocks again I envision using tire chains to form a sling like configuration.
A twist clevis works well to attach chains to the drawbar.
2006 Hitch and Trailers Inc. 12ft S/A Utility Trailer (A61574)
2006 Hitch and...
2021 CATERPILLAR 299D3 SKID STEER (A64279)
2021 CATERPILLAR...
2016 VOLVO EC250EL EXCAVATOR (A64279)
2016 VOLVO EC250EL...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
2 Row Cultivator (A64047)
2 Row Cultivator...
CASE 586H ROUGH TERRAIN FORKLIFT (A64279)
CASE 586H ROUGH...
