Pole Barn??
/ Pole Barn?? #1
dieselscout80
Elite Member
South Carolina
New Holland TC45DA
We are building a small pole barn for hay and horses.
I want to insulate it. The barn is going to be sheeted with OSB and then vinyl siding.
Should we put foam boards on before or after I sheet it?
/ Pole Barn?? #4
On a pole barn, I'm not sure I would want foam between the structure and siding. I think I would want the connection between the poles, girts and the siding to have minimum compressibility to maximize rigidity and minimize the potential for the screws to loosen up. On mine I put housewrap over the girts and filled in between the poles inside the girts with foam (and finished with a plastic vapor barrier inside the poles).
/ Pole Barn?? #5
Why are you using foam for the walls? Best value for your money is going to be regular fiberglass wall insulation.
If you really want to pay for foam sheets, it would go on over your OSB.
Compare the R value of the foam to either R13 or R19 for the fiberglass
Eddie
/ Pole Barn??
Eddie
I really don't want to finish the inside for hay storage, but I may have too.
/ Pole Barn??
I my Father in law had two buildings one was insulated and the other was not and it was unbearable in the non-insulated one.
Besides hay there will be horses and tack.
/ Pole Barn?? #9
I think OSB, I think mold magnet. Why not use tin on the side walls? At least for the roof, I would lay foil sided bubble wrap over the purlins.
/ Pole Barn??
This is an addition on a current building and it needs to match.
/ Pole Barn?? #11
I stopped using that foil bubble wrap crap. It deteriotes after 8-10 years. Using another product that is white on bottom, foil on top and fiberglass in between. Has an R10 value. Use it on roof and siding.
/ Pole Barn??
Do you have a name or link to the product?
/ Pole Barn?? #14
My 52x44 pole barn was built in 1997. It's sheathed with 7/16 OSB with vinyl siding and 3 tab shingles on the roof and seamless gullets with standard facia and vented soffits. The roof has a ridge vent. The entire space has 5.5" of concrete for a floor and no issues whatever. Much better than metal for noise and sweating is non existent.
Chris
/ Pole Barn?? #15
I'll see if I can find one when I get home tomorrow.
/ Pole Barn?? #16
Yours is the first comment on failure that I have heard about bubble wrap. I have sold off properties where I used it before I noticed an issue. There used to be a material in a roll that was vinyl with fiberglass that I have seen break down.
/ Pole Barn?? #17
Chris
Is the barn used for animals? Horse barns can have moisture issues, that's why I mentioned it.
/ Pole Barn?? #18
I did my big pole barn in T111 and a little pole barn in OSB and vinyl. No foam except in the tack room along with fiberglass 6" batt insulation. White shingle roof with continuous ridge vent. Barn is always comfortable. Not really any hotter than outside. Outside walls are 12 feet high with a continous window between 8 and 10 feet. Pole Barn Building
/ Pole Barn?? #19
I have several buildings that it has happened on. Purchased it from MWI Components.
LOT OF 2" SQUARE TUBING (A64278)
LOT OF 2" SQUARE...
2012 Ford F-450 4x4 Liftmoore 1640 4,000lb. Crane Service Truck (A64556)
2012 Ford F-450...
2023 Dodge Durango AWD SUV (A64557)
2023 Dodge Durango...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
New 2x27 Ratchet Strap (A65583)
New 2x27 Ratchet...
T/A Drop Deck Equipment Trailer (A64556)
T/A Drop Deck...
