Xu5055c third remote
/ Xu5055c third remote #1
kingarthur13
Austin, TX
XU5055C
Anyone know a good source to get the third remote parts for an ls xu5055c tractor?
/ Xu5055c third remote #3
believe that 3rd rear remote is an available "dealer installed" option on the XU's.
I actually want it for the rear. I had the top and side link hydros installed and wanted a third "non detent" remote to control the top link. I could remove the detent in the blue lever but then I lose that function. Here is a pic of the valve body. I thought it had the room for the third but the dealer is saying that the extra ports are for something else (possibly secondary input ports) IMG_3692.jpgIMG_3693.jpg I am waiting for the dealer cost to add the dealers option but wanted to see if there were other guys that have done this and the cost on it.
/ Xu5055c third remote #5
Typically with mono block valves, what you see is what you have. No additions like stacking valves. If there is a 3 valve option, the time to have done that would have been when-before you purchased it. There is no 3rd rear remote option shown on the website. My guess is that you will need to go with an electric diverter valve, but that is not getting you the non detent valve that you are looking for. :(
Just so you have something to reference too, A single rear diverter kit runs $715 shipped to you.
I hope that the dealer comes up with an OEM solution for you.
dealer has an OEM option and can install it for me. I was looking for secondary options
/ Xu5055c third remote #7
My guess is that the dealer would be installing an electric over hydraulic valve. So no float, no feathering. It is either open or closed.
But I may be wrong also, I hope so for your sake.
Please keep us informed with what your options end up being and which option you get.
Thanks :scratchchin:
(2) 23.5L/55-26 TITAN TIRES & 10 LUG RIMS (A63291)
(2) 23.5L/55-26...
Ditch Witch 6510 DD Trencher 4x4 (A62613)
Ditch Witch 6510...
2014 Sullair 185DPQ 100psi Towable Air Compressor (A61572)
2014 Sullair...
UNUSED WOLVERINE HYD ADJUSTABLE BALE SQUEEZE (A64281)
UNUSED WOLVERINE...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2022 EZ-GO ELITE...
