Learning to weld
/ Learning to weld #1
Stick895
Gold Member
Chesterfield, VA
LS3037H
I've seen a lot of posts regarding this topic and I thought I would offer up my :twocents:. I have always wanted to learn so after I retired and got the time I started researching. I didn't want to spend 2 nights a week for weeks at a community college and most of them and technical programs are aimed at getting people certified for welding jobs. I figured if Tig was the hardest to learn, if I learned that, then the other methods would follow. Well, let me tell you, Lincoln welding school is the ticket. I had never welded a thing in my life but I took a Basic Tig course and learned the basics of Tig. Of course, I need lots of pratice to be good at Tig, but it was a week long course dedicated to just Tig so it was just what I was looking for. This is not an ad for them just my experience and my recommendation. We learned mild steel, aluminum and stainless.
/ Learning to weld #2
Sounds like me- except I've been stick welding (AC) for 40 years. Also did some playing with a cheap MIG a couple years back. Now I'm self-teaching TIG with a $720 AHP 200. The guys at the shop are helpful and I learn a lot from them. With TIG it's the little things like tungsten prep that drive me nuts. Found out yesterday that I was grinding my tips completely wrong and using them that way would make even the most accomplished pro look like a newbie.
/ Learning to weld #3
One of the moderators over on Welding Web posted a picture a few years ago of how he sharpens his tungsten. Use a drill motor to hold / rotate your tungsten on a bench grinder. It's best to stand behind the bench grinder if you can. Less chance of the tungsten getting jammed in the grinding wheel that way. You can raise or lower the drill motor to get the angle you want on the tungsten.
/ Learning to weld #4
That's the way I was doing it, but I had the drill on high speed so it was making spiral striations on the tip. Kenny uses a belt sander and the drill revolves slowly to keep the striations parallel to the shaft. I'm going to try it that way this evening.
/ Learning to weld #5
Forgot to mention the guys on this forum have a bunch of helpful input as well. Ran a few beads after re-doing my tungsten:
1/8" Al plate, 80A, -25% balance, 20CFM, Freq 90hz
/ Learning to weld #6
I wouldn't say that learning TIG necessarily makes the other processes easier to learn. TIG will teach you about the puddle though.
/ Learning to weld #7
Definitely not. It is different and I think the closest thing I've done that comes close is PCB soldering. Was in electronics most of my career. If you go from TIG to high amp stick welding you'll need to learn to keep further away from the arc.
/ Learning to weld #8
Tig welding is just plain fun! What you see is what you get-literally! If your welding something that needs to be water or air tight, this is the process I prefer.
/ Learning to weld #9
I always thought in my experience that TIG was very close in concept to gas welding. Now, I ain't no expert in either one , but that is what I think
/ Learning to weld #10
I agree! Gas welding was one of the first processes I learned. Tig gives you a very similar visual, except you don't have the hissing,occasional popping and sparking. I consider Tig welding as therapy!
/ Learning to weld #13
It is. I took a welding class, and the first half was all O/A . I wasn't intersted in that, but when we started TIG it was so easy. And being able to adjust heat on the fly was a luxury.
2018 LIEBHERR A900C LITRONIC WHEELED EXCAVATOR (A63276)
2018 LIEBHERR...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
(3) FANS (A63291)
(3) FANS (A63291)
1998 Mazda B2500 (A57149)
1998 Mazda B2500...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
10in Digging Tooth Bucket Excavator Attachment (A64194)
10in Digging Tooth...
