The shear pin is almost idiot proof as long as you dont go using high strength grade 8 bolts.
The slip clutch pushes the u joints closer together and thus the angle they have to operate at is increased which shortens their life.
PTO angle of 5 deg has a life of 450 hours
PTO angle of 10 deg has a life of 195 hours
PTO angle of 15 deg has a life of 90 hours
PTO angle of 20 deg has a life of 40 hours
PTO angle of 25 deg has a life of 20 hours
A small change in pto shaft angle dramatically shortens the life of the u joints.
Dave M7040
My approach is to use shear pins on devices that employ rubber belts, clutches on those that don't. I have a rotary rough cut mower, on which I use a slip clutch. And I have a flail type rough cut mower, on which I use a shear pin. Logic is that slippage should occur in the belt drive before it gets to the point of snapping a shear pin. But I did get into a situation recently where I hit dirt with the flails, which slowed the belts down too fast to slip - at which point the shear pin snapped.So, just wondering what the pros and cons are of each, specifically on a rough cut mower.
Dave M7040
How does a slip clutch change the angle of the pto shaft? It's part it and has nothing to do with the angle of it. How high you cut is the only way to change the angle of the drive shaft.
Eddie
Dave M7040
By extending the gearbox more [straight out]. ... Whatever misalignment then has to be accommodated over a shorter length.How does a slip clutch change the angle of the pto shaft? It's part it and has nothing to do with the angle of it. How high you cut is the only way to change the angle of the drive shaft.
Eddie
Disagreed. ... But maybe its because I havnt seen pto shafts with a slip clutch in them, but rather on them. --- outside the U Joints.Agreed.
Supporting truth is not argumentative. ... Documentary might be a good word.No trying in any way to be argumentative with this reply.
What affects the angle that the pto shaft has to accommodate, assuming the implement is on the ground at its lowest position, are two factors, 1: how far apart are the tractor and implement pto shafts in a vertical plane, shown as (A-B) =C and, and 2: the actual length (l) that the real pto shaft has between the u joints at each end.
This diagram is from major pto shaft manufacturer which shows the process.
My point is that once you put the slip clutch assembly unto the tractor PTO stub, then the actual pto shaft has to be shorter to fit in the same place and the angles of the u joints are, without a doubt, operating at a greater angle which dramatically shortens theirs lives.
Dave M7040
Im betting test conditions to establish the data points were far from real world use.Interesting documentation, but since I've never had a drive line failure on any of our slip clutch equipped machines, I, like pretty much all the all the farmers in my area, will keep using them.
The predominant cutter used by farmers here is a 15' batwing with slip clutch, so following the logic that use of a slip clutch will dramatically shorten their lives the fields should be littered with parts resulting in the abandonment of their use.
No intent to be argumentative, just discussing and trying to learn.
"In theory, there is no difference between theory and practice. But in practice, there is." Yogi Berra
