BX25D engine brakign vid
/ BX25D engine brakign vid #1
millsan1
Gold Member
Riegelsville, PA
Mahindra 2538 Cab, Volvo ECR40D Excavator
In another thread there was a discussion re: whether or not the new BX series has engine or trans braking.
I am far from an expert and I can only speak to my BX, but the transmission or engine braking works just fine on mine.
This video show me driving my BX25D. I am running at 3,000 RPM, in high gear 2WD. The only thing I do is take my foot off the pedal and machine comes to a rapid stop, I would say with 25 feet.
/ BX25D engine brakign vid #2
If it takes 25' to stop when pedal released it is NOT working right. It should stop within a few feet or less. What about in low at a low speed? How short is the stopping distance?
In low gear, or lower speeds, stop is almost instant. I rarely use the brakes themselves, except to hold myself in place. If I just let up on the pedal when working, the stop is abrupt.
I did this demo as a worst case scenario. Full speed, full throttle. 25' is 1 length from about 12 MPH. 25' is a guess on my part.
/ BX25D engine brakign vid #4
Mine works about the same. When going backwards then release the pedal, the stop is immediate. When going forward, it seems to slowly slow down. Don't know if this is HST adjustment or pedal adjustment.
I used to use a New Holland. When you released the pedal, it stopped dead in its tracks... and would not move, even if pointed downhill. Wish my BX did that.
/ BX25D engine brakign vid #5
If you do that on other Kubota's, you would practically get thrown over the steering wheel. 25 ft is not typical, and I think that is what people are complaining about. The higher the gear and speed, the more abrupt and violent it would feel. I know when road transporting my Kubotas in high gear, I have to very gently feather off the pedal before coming to a stop otherwise it's a very abrupt and jerky stop.
The issue isn't really engine braking -- it has to do with how quickly the HST treadle is allowed to return to center by the damper. The resulting braking action is independent of engine RPM for the most part (other than the RPM determined the starting speed of course). It's caused by the HST itself.
Engine braking generally happens when the transmission drives against the engine and the vehicle's motion raises engine RPMs. That can't really happen with an HST setup, it's more of something you get with manual or automatic transmissions. An HST is a separate hydraulic pump arrangement, and it can't really back-load an engine (can certainly forward-load it though).
/ BX25D engine brakign vid #6
Ive seen numerous posts on this.
Per workshop manual its called Dynamic Braking. There is an adjustable Hst spring.
Turn on engine, full rpms, 2wd and in high range.
On concrtete level ground at full speed, let off and it should stop at 9.8'
I checked mine last fall and it was a little under. Im used to it so I'm happy with it. Any less and I'd be in the bucket.
/ BX25D engine brakign vid #7
Many people are/were happy with the abrupt stop in reverse on the BXxx50 series and that's fine but they were/are wrong. Many people will be happy/OK with the rolling stop on the BX25Ds which is also wrong. I wasn't happy with the BX2350 abrupt stop and traded it back to Kubota dealer and rec'd some additional compensation from Kubota. I traded it to a BX2660 and it stopped right in reverse.
I've taken my BX25D back to the dealer and the master mechanic worked on it twice and said no more adjustment available. It's still "not right" but I'll live with it. I'll never say it's right as long as it keeps rolling after the foot pedal is released. What ever the reason and lots of reasons and fixes were given by owners/observers for the BXxx50 series but none of them ever worked to stop the abrupt stop in reverse. Kubota has done something in the BX25D dynamic braking system that has made it wrong. I believe the next series will be fixed on the fix will be done to new BX25Ds with no announcement. If I were buying again I'd refuse the machine until the dynamic braking was fixed/changed. I'm certain all of the BX25Ds on Barlows lot does the same or did a month ago when I took mine in.
What ever the reason or fix, it should immediately stop when the pedal is released abruptly and easing back on the pedal should let it come to a stop based on the amount of let off on the pedal.
My RTV1140 will throw me thru the windshield if I let off abruptly on the foot pedal but will gradually stop with easing off the pedal. That's operating right. This also isn't my first BX25 or even my first Kubota HST in the BX, B or/and L size.
/ BX25D engine brakign vid #8
It looks pretty abrupt to me, without being dangerous. My tractor is the same. In lower gear it is a somewhat more violent deceleration, but in higher gear it slows down and stops through about one tractor length. My tractor is also more likely to roll in higher gears, but in Low it stops dead, even on a fairly steep incline.
/ BX25D engine brakign vid #9
Exactly. Yours is working like about all HSTs but the new BX25D is NOT stopping in low gear at low speed like yours. It continues to roll in low gear at low speed and will continue to roll down a slight incline if the brake isn't applied. Mine seems to stop a bit more abrupt in reverse like it should and some times it stops better in forward but often times it keeps rolling which is wrong. Yours is right but this new BX25D isn't right and isn't doing like yours and should..
/ BX25D engine brakign vid #10
I see, didn't realize that was part of the issue. That would be annoying.
Well, as I posted, I am a complete newbie. Will take some more vids in different setups and do some measurements.
I live on pretty steep property, so can get some idea there as well.
Thanks for the information guys.
/ BX25D engine brakign vid #12
I'm having a hard time following you. You ARE or ARE NOT OK with the abrupt stop when taking your foot off of the pedal. It seems like you contradicted / flip-flopped several times here.
/ BX25D engine brakign vid #13
It doesn't stop abrupt when foot is taken off the pedal it keeps coasting That is the BX25D. I WANT it to stop and NOT KEEP COASTING WHEN I TAKE MY FOOT OFF THE PEDAL like an HST is supposed to do.
I also mentioned the abrupt stop in the BXxx50 series of days gone by, different machine (NOT THE BX25D that is the topic here) but was just an example of some Kubota engineering mistakes.
I've owned several HST Kubotas and this one, the BX25D, is WRONG, flawed, not right because it doesn't stop when the foot pedal is released, it keeps coasting right into the truck that I'm trying to load a two bottom plow into the bed. It stops when the brake pedal is pushed which has been moved to the left side from the right side where it has been for the 12 years that I've owned HST Kubotas.
I saw No flip flopping in my post. I did NOT LIKE the ABRUPT STOP in the BXxx50 series in reverse that no other HST Kubota did (One I owned several years ago a BX2350 not the BX25D I own now). It would snap ones back/neck and COULD NOT be feathered out with the pedal like all other Kubota HSTs could be done, feathered out to a gradual stop.
I DON'T LIKE THE COASTING (TALKING ABOUT CURRENT BX25D NOW AND NOT THE 50 series of bygone days) in forward when the pedal is released on the BX25D that I now own because no other HST Kubota that I've ever owned has done it.
Does your BX2370 keep going when you release the pedal on a level surface or slight decline or stop?
/ BX25D engine brakign vid #14
Yup, my 2370 still moves after taking my foot off of the pedal, which I don't like. My response to you post was just trying to understand you better.
I think my pedal needs to be adjusted a little, so that it goes back to neutral sooner... however that wont fix the "still goes downhill" issue. That must be some sort of HST adjustment. I would like to figure that one out. There just doesn't seem to be any "locking" of the hst when in neutral, which there should be.
/ BX25D engine brakign vid #15
I know you guys are talking about the BX25D but I checked my BX2660 tonite and in high range, full rpms, 2wd and full speed, it stopped at about 8 feet. I've been unhappy with mine at lower throttle settings, which is where it doesn't stop as quickly as I think it should or as quickly as my BX23 does.
/ BX25D engine brakign vid #16
Does yours keep rolling at slow speed in low gear on a flat surface after removing your foot from the pedal? That's what the new BX25D IS DOING, still rolling in turtle speed and not full out speed. Even at a slow crawl it will keep rolling forward when foot is removed from pedal. That is wrong for an HST.
I had a BX2660 along with several other BXs and even a earlier BX25 before they were labeled BX25D and they ALL stopped when I removed my foot from the pedal in low gear at low ground speed. Also all of the Bs and the L HSTs stopped when I released my foot from the pedal in low speed. At fast speed full out that one continues to roll a few feet isn't an issue or problem for me since I am not expecting to fly up to the side of a truck to dump a load or a 2 bottom plow but I want/expect the HST tractor to STOP at slow speed when doing more precise work and my current BX25D doesn't, It keeps coasting until I mash on the brake which I've rarely ever used on an HST Kubota other than when I stop it or get off the tractor and lock the brake down.
On a hillside of which I have many my previous HSTs will stop when I let off the foot pedal and may creep a bit after it stops until I touch the foot pedal in reverse or hold the foot brake down if I'm going to set on the tractor for awhile on the side of the hill and to me that's OK and normal.
Not stopping on level ground at slow creep speed when the pedal on an HST is let off is NOT normal to me. In fact I'm saying it's wrong, from my experience.
/ BX25D engine brakign vid #17
Sounds like you would be just as well off with a gear transmission if you have to brake at each stop. I have only driven 3 Kubotas (my daughter 2920?, my B26 and my RTV and they all stopped abruptly when the HST pedal is released but could be feathered down to a slow stop. I wouldn't keep one that creeps forward when the pedal is released.
/ BX25D engine brakign vid #18
Of the 20+ Kubotas :) one was a B2320 geared. One of my first drives and I let off the pedal and it kept going and then I remembered the clutch and depressed it and it kept going and barely bumped a rental unit until I PRESSED THE BRAKE PEDAL.:ashamed: Yes, that was one of my very short term owned Kubotas and if it had only been an HST I would have loved it instead of hated it. Unless it had performed like my current new BX25D that also keeps going when the pedal is let off. I have taken it to dealer and they adjusted it twice with slight improvement but it's still not right. The fixer is Barlows oldest most experienced master mechanic and he said that's as good as he can do with it. It's a Kubota engineering issue that's going to have to be fixed from "Headquarters" instead of the local dealer fix or until headquarters sends a new part or an engineered fix which they never did with the BXxx50 series abrupt stop in reverse that couldn't be feathered that didn't act the same in forward.
As long as no other buyers/owners complain or refuse to buy them Kubota won't fix them.
/ BX25D engine brakign vid #19
Does yours keep rolling at slow speed in low gear on a flat surface after removing your foot from the pedal? That's what the new BX25D IS DOING, still rolling in turtle speed and not full out speed. Even at a slow crawl it will keep rolling forward when foot is removed from pedal. That is wrong for an HST. . . .
Yes it still rolls forward after I release the pedal in low gear, but it seems to have gotten better since I greased the absolute living p!ss out of my HST pedal linkage. I bought it used, and I think the prior owner may have failed to grease that linkage through the hole in the floorboard.
If/when it FINALLY stops raining here, I'll run some tests on my BX2660 in low gear at low/mid/high throttle settings to see how far it rolls after releasing the pedal.
I agree that it should NOT continue to roll forward after you release the pedal. For people who haven't experienced this, it is very much like a tractor that is freewheeling forward after you have mashed the clutch, although not quite as freewheeling as that.
I can tell you that my BX23 has always been perfect in this regard, or at least what I consider to be perfect. I.e., I release the HST pedal and it stops. Period. With no drama.
/ BX25D engine brakign vid #20
johnthomas, I d like to see a video of what yours does if you get a chance. Ive read a few of your posts on this and have tested my bx2370 a dozen times. sometimes I think it rolls and sometimes I don't...... im mostly concerned because im more than half way there with my saving towards trading in on a bx25d. should be a lifetime machine for me and the one I really should have bought to begin with but live and learn. I want a new Kubota but maybe I need to look for used or even another brand if there are issues. I might get lucky and they fix this issue, if its systemic, by time i buy or I might get a good one but I kinda need to know what exactly its doing so I know how to test for it.
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
2016 Great Dane 50ft. T/A Refrigerated Van Reefer Trailer (A61573)
2016 Great Dane...
Year: 2008 Make: GMC Model: Yukon XL Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 221,739 (A61574)
Year: 2008 Make...
2019 CATERPILLAR M316F MOBILE EXCAVATOR (A63276)
2019 CATERPILLAR...
(2) 380/95-38 ROW CROP TIRES & 10 LUG RIMS (A63291)
(2) 380/95-38 ROW...
