Buying Advice Tips and Guidelines before buying a Zero Turn Mower
/ Tips and Guidelines before buying a Zero Turn Mower #61
I'm out of touch with new pricing on my super Z diesel... I ended up finding mine used with only 174 hrs at a Dealership in Ohio. Only paid around $8k for it.
That sounds like a good deal
/ Tips and Guidelines before buying a Zero Turn Mower #62
Thanks... I was most likely going to spend around $6500 on a 60" gas ZTR, and I wasn't completely sure on which brand I was going with, but when I found this deal, I couldn't pass it up. Great mower. I think it runs quieter than a gasser. In theory, the engine should last alot longer too, and use less fuel. But, I wouldn't mind having a 35 HP Kaw gasser... My diesel is only rated around 25 HP, and there are times when I could use a little more HP. Of course, I just slow down and it's all good. My buddy has a 31 HP Kaw gasser in his 61" Scag, and the combination of my larger deck width and lower HP means I can't mow as quickly in taller grass.
/ Tips and Guidelines before buying a Zero Turn Mower #63
How is it on hills and has there been any issues with is?
/ Tips and Guidelines before buying a Zero Turn Mower #64
Does fine on hills... It is heavier than most ZTR's, so I would say it probably doesn't hold as well as lighter machines would.
No problems with it.
/ Tips and Guidelines before buying a Zero Turn Mower #65
Does fine on hills... It is heavier than most ZTR's, so I would say it probably doesn't hold as well as lighter machines would. No problems with it.
If you get a chance post a few pics if you don't mind. Curious to see the size vs kubota ZD line
/ Tips and Guidelines before buying a Zero Turn Mower #66
TSO
Just looked it up on tractor house , pretty good size machine.
/ Tips and Guidelines before buying a Zero Turn Mower #67
TSO
This is a picture of my 2013 Super Z gas model w/72" deck setting beside a Hustler FasTrak 54" that it replaced.
It may give you an idea on size.
/ Tips and Guidelines before buying a Zero Turn Mower #68
Good pic... and my Super Z Diesel is even bigger, longer in the rear to accommodate the engine and cooling system.
/ Tips and Guidelines before buying a Zero Turn Mower #70
Apparently, I'm doing it wrong.
No, you are OK just ad a few more bricks!:thumbsup:
The flip-up on the Hustler Raptor adds $1000 to the price so you can afford a few more bricks.
/ Tips and Guidelines before buying a Zero Turn Mower #71
Tons of great information here, Thank you so much to you all! I believe I'm going to buy a Steering Wheel Zero Turn, I have alot of 10-15 degree hilly areas in my yard of about 1 1/2 acres. I'm thinking the new Exmark Quest S Series Front Steer is gonna be the winner.
2004 Ford F-350 4x4 Crew Cab Pickup Truck (A61568)
2004 Ford F-350...
WHEEL BARROW (A62131)
JOHN DEERE 10' ROTARY MOWER (A62130)
JOHN DEERE 10'...
PALLET OF ARMSTRONG CEILINGTILE (A62131)
PALLET OF...
UNUSED JCT 4 PRONG BALE SPEAR (A62131)
UNUSED JCT 4 PRONG...
2022 Case 5550 Trident Spreader LOW HOUR (A63118)
2022 Case 5550...
