Buying Advice Tips and Guidelines before buying a Zero Turn Mower
/ Tips and Guidelines before buying a Zero Turn Mower #61
I'm out of touch with new pricing on my super Z diesel... I ended up finding mine used with only 174 hrs at a Dealership in Ohio. Only paid around $8k for it.
That sounds like a good deal
/ Tips and Guidelines before buying a Zero Turn Mower #62
Thanks... I was most likely going to spend around $6500 on a 60" gas ZTR, and I wasn't completely sure on which brand I was going with, but when I found this deal, I couldn't pass it up. Great mower. I think it runs quieter than a gasser. In theory, the engine should last alot longer too, and use less fuel. But, I wouldn't mind having a 35 HP Kaw gasser... My diesel is only rated around 25 HP, and there are times when I could use a little more HP. Of course, I just slow down and it's all good. My buddy has a 31 HP Kaw gasser in his 61" Scag, and the combination of my larger deck width and lower HP means I can't mow as quickly in taller grass.
/ Tips and Guidelines before buying a Zero Turn Mower #63
How is it on hills and has there been any issues with is?
/ Tips and Guidelines before buying a Zero Turn Mower #64
Does fine on hills... It is heavier than most ZTR's, so I would say it probably doesn't hold as well as lighter machines would.
No problems with it.
/ Tips and Guidelines before buying a Zero Turn Mower #65
Does fine on hills... It is heavier than most ZTR's, so I would say it probably doesn't hold as well as lighter machines would. No problems with it.
If you get a chance post a few pics if you don't mind. Curious to see the size vs kubota ZD line
/ Tips and Guidelines before buying a Zero Turn Mower #66
TSO
Just looked it up on tractor house , pretty good size machine.
/ Tips and Guidelines before buying a Zero Turn Mower #67
TSO
This is a picture of my 2013 Super Z gas model w/72" deck setting beside a Hustler FasTrak 54" that it replaced.
It may give you an idea on size.
/ Tips and Guidelines before buying a Zero Turn Mower #68
Good pic... and my Super Z Diesel is even bigger, longer in the rear to accommodate the engine and cooling system.
/ Tips and Guidelines before buying a Zero Turn Mower #70
Apparently, I'm doing it wrong.
No, you are OK just ad a few more bricks!:thumbsup:
The flip-up on the Hustler Raptor adds $1000 to the price so you can afford a few more bricks.
/ Tips and Guidelines before buying a Zero Turn Mower #71
Tons of great information here, Thank you so much to you all! I believe I'm going to buy a Steering Wheel Zero Turn, I have alot of 10-15 degree hilly areas in my yard of about 1 1/2 acres. I'm thinking the new Exmark Quest S Series Front Steer is gonna be the winner.
2014 John Deere Z930M Zero Turn (A63116)
2014 John Deere...
2018 Ram 1500 Reefer Meal Delivery Truck (A61568)
2018 Ram 1500...
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
300 GALLON FUEL TANK (A62131)
300 GALLON FUEL...
JLG E300AJ (A60462)
JLG E300AJ (A60462)
2018 VERMEER BC1000 XL PORTABLE WOOD CHIPPER (A63276)
2018 VERMEER...
