brs077
Hey all, I've got a 2014 NH workmaster 40 and a lot of thick brush to clear. As you can see in the picture, this is the tractor parked in the middle of what I'd like to clear. Most of it is less than 1.5" thick, but it is dense. Will this tractor be strong enough to pull a rotary cutter big enough to clear it?
Regardless, I've been looking at cutters and the Rhino 172 and Woods BB72x are both available nearby, as is the NH model. All three are similarly priced and slip clutch driven, with similar specs. Does one have a better track record? The WM40 has a 3ph lift capacity of 1300 lbs, and is 38 hp, 31hp at the pto. Would the loader be enough ballast, or would I need additional weight up front? Any other questions I should be asking?
