Building a Chisel Plow for my Kubota
/ Building a Chisel Plow for my Kubota #1
zionview
Central PA
BX2200 and B8200HST Kubotas, White GT 2550H, Simplicity 7116H
Just putting the finishing touches on a 4 shank chisel plow for my B8200. I used John Deere 1010 field cultivator shanks I got at a farm equipment salvage yard. They had duck foot sweeps on them, so I cut them down to chisel width. Hopefully, I'll get to try it out tomorrow or Monday. I'll finish the paint after I make any final adjustments. Sorry about the messy shop!
/ Building a Chisel Plow for my Kubota #2
Looks nice - my favorite kind of plow. I have one with sweeps (shovels) and one with chisel points. This year I got the fields ready to plant without even hooking up the tandem disc. They make chisel points that will bolt on for around $10-15 each.
It will be interesting to see how the bota does. Running shallow you should be ok but going deep it may be more than the tractor will want. I have a ten foot wide 11 shank chisel and it will stop my tractor dead in its tracks if I get too deep and my tractor has 130hp, duals, and weighs close to 15,000lb (it is the tractor and plow in my avatar).
bdog, I got it in the ground yesterday in one of the gardens. I was able to pull it about 4 1/2 inches deep(4WD low range, couldn't move it in 2WD). The soil is nice and mellow, lots of organic matter. I was hoping to get closer to 6 inches, but this will have to do. The rototiller doesn't go much deeper, anyway. With the weights, chisel and driver, the outfit comes in right around 2000 or so pounds. My whole idea was to do some primary tillage to make things easier on the tiller, and I got that. I was pleasantly surprised at the tractor. For being rated at 19HP, it pulled it nicely. I was really cautious about building this. When we farmed, I pulled an 11-point Case/IH Hi-clearance chisel at 8 inches with a 2-105 White. I didn't like the beating the tiller took in untouched ground. It ran easy and quiet after the chisel. I tried moldboarding ahead of the tiller last year, but my wife actually suggested the chisel after she twisted an ankle in an open furrow, and our 1 1/2 yr. old granddaughter fell face first into the same furrow. I'm like you, I always did prefer chiseling.
/ Building a Chisel Plow for my Kubota #4
I took the shovel off of my potato plow and put a point on it and did mu gardens about a foot deep and a foot apart. It was all my little massey would do but I wanted to break up any hard pan from other users.
/ Building a Chisel Plow for my Kubota #5
I made a single tooth ripper from some scrap steel I had laying around. Ripped my garden on about 3 foot centers and full depth (about 18") last fall.
I can see the difference already in how well the garden is draining after the Spring thaw.
Another couple of weeks I'll be able to till it and plant. Not much point in planting anything before Memorial Day in this area. Peas and potatoes maybe, but that's it.
/ Building a Chisel Plow for my Kubota #6
Good job! Did you fabricate the gray planter?
/ Building a Chisel Plow for my Kubota #7
Yup, I enjoy raising flowers, have beds all over the place. Makes it a PITA to mow my front yard! :laughing:
I also welded up the hangar, mostly from old disk harrow parts and a handful of dump rake teeth.
I've been working on that planter for about a year on and off. It's a ground-up build that incorporated seed openers from an old John Deere Van Brunt grain drill. Some day, hopefully, I'll get it done. Way too many projects.
Love the subsoiler! AND the plant hanger!
/ Building a Chisel Plow for my Kubota #10
Whoops, I thought he was talking to me. Sorry for the derail.
5-6 YD BLUE LINE GRIZZLY SCREENER (A58214)
5-6 YD BLUE LINE...
2011 CATERPILLAR 305.5D CR EXCAVATOR (A62129)
2011 CATERPILLAR...
2008 Mercury Milan Sedan (A59231)
2008 Mercury Milan...
Toro Reelmaster 6500 D (A61166)
Toro Reelmaster...
2010 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2010 DRAGON 150...
2023 Chevrolet Express Van, VIN # 1GCWGBFP8P1104620 (A61165)
2023 Chevrolet...
