Budget counter weight.
/ Budget counter weight. #1
vtsnowedin
Elite Member
central Vermont
John Deere 5045E
Having more time then money and a lot of junk lying around I decided to build a counter weight for the 5045E on as low a budget as possible. Having a steel 55 gallon drum in hand and a few old hardened bags of mortar mix, or cement etc. That has become the plan. n o great revelation here .I'm just going to do it about the same as every body else has.
Anyway today I took the first step. I found a #8 rebar in the bone pile and cut it to length and drilled the holes in the ends for the lynch pins. I ground off most of the rebar deformations on the ends even though it fit through Cat. 2 bushings as it was. I regained my respect for grade 60 steel and had to relearn how to sharpen drill bits.
So far my counter weight weighs about ten pounds. :D
/ Budget counter weight. #2
Rebar is melted down scrap so it can be mild steel or carbon steel or a mixture of the two. Sounds like you have some carbon steel in yours. I would buy a bag or two of crete mix and bond all of the stuff you are adding to your weight.
That is in the plan. Just how many remains to be determined. Some of the old cement and mortar mix left overs I have lying around may be able to be mixed with a little effort and some of it is just shove the whole thing bag and all into the crete. I have to get the drum from its hiding place and get some holes through it for the cross bar then work out the top link tabs. One expense I may have to spring for is a drill bit large enough to drill the holes for the top pin. I don't have anything that big in hand.
/ Budget counter weight. #4
I would weld the top link in some way that it would be attached to your bottom pins. I would also weld some pieces of rebar on the horizontal,so it will not spin. bust your junk bags up and pour in some good quick crete. Paint and decals later. Top of barrel left 4 inches high for extra chain storage.
/ Budget counter weight. #5
This seems like a good use for your bent crossbar. Probably still stronger than the rebar.
I have some #4 bar to connect the two. I'm thinking the top link tabs need to come out of the side of the barrel eighteen inches above the cross bar instead of sticking up out of the top of the concrete.
Yes to your other suggestions.
/ Budget counter weight. #7
Rebar is a forged steel so it gets some work hardening, plus as stated before it comes from basically any steel that can produce the proper yield strength...usually 60 ksi
Yeah the bar I used was grade 60 and they often test out 70 to 80 kips /in^2. I don't recall a rebar sample failing destructive testing in the last twenty-five years. One of the last bridge decks I worked on had all its rebar made out of stainless steel. It will be thirty years or more before we know if that solves the deck deterioration problems we have in the north due to the use of road salt and over loaded log trucks.
The counter weight project got set aside for a few days while I put in a food plot and do family stuff. I just got back from a three day weekend where we combined a friends daughters wedding with a weekend away for our 38th anniversary. I even indulged SWMBO by letting her drag me into a Macy"s at the Mall of New Hampshire for way more shopping and watching her try on dresses then I usually endure. ;)
/ Budget counter weight. #9
I used 1 1/2'' pipe and pins from Tractor supply. Metal from old dock hardware and seven 80 lb. bags of concrete mix.
/ Budget counter weight. #10
Update w/pics??? :confused3:
/ Budget counter weight. #12
Stainless Rebar, can you say -->$$$<-- we are going to try using fiberglass rebar on a upcoming project for the same reason
/ Budget counter weight. #13
Ballast barrel is a great place to get rid of any old brake drums or rotors lying around too. If you haul scrap fairly often may be worth more to you selling it but it's a cheap way to add weight!
Oh I plan on adding quite a few bits and pieces from my scrap pile including seveal old brake drums. I think I've got enough scrap around to get the finished drum up to about 1300 lbs.
/ Budget counter weight. #15
Change that to 15 inches and you can use the JD i-match 3 point quick hitch.
/ Budget counter weight. #16
2022 CATERPILLAR 289D3 SKID STEER (A64279)
2022 CATERPILLAR...
Hydro-Ax 721E Articulating Mulching Forestry Tractor/ Land Clearing (A66734)
Hydro-Ax 721E...
2010 Sellick S-100 10,000lb Rough Terrain Straight Mast Forklift (A68183)
2010 Sellick S-100...
2008 MACK CHU613 (INOPERABLE) (A67714)
2008 MACK CHU613...
2013 WACKER NEUSON  TLN8 LIGHT PLANT (A67714)
2013 WACKER NEUSON...
Caterpillar 3400 Series Diesel Generator (A66734)
Caterpillar 3400...
