Quickie log-drag, (paper-thin MIG weld)
/ Quickie log-drag, (paper-thin MIG weld) #41
I'd use a wire rope come along, with slip hook on the wire rope. Two wraps around the log, clip the hook on the wire rope with bail of hook facing tractor, and working end of come along at top of picking frame.;)
/ Quickie log-drag, (paper-thin MIG weld) #42
10' chain will handle a 30" log depending how much tail you need to get on your implement and how close you can get the tractor.
I have an 8' and 12' with slip hooks for skidding. 12'er mainly helps when I can't get close enough. Then I have chains with regular hooks to extend with if needed.
I have four 20 footers. Every time I go out I wish i'da cut one into a couple 10s, always forget to do it when I get back. This post is my reminder.
/ Quickie log-drag, (paper-thin MIG weld) #44
For a quick way to shorten chains, make up a couple of these and keep one in your tractor tool box.
Terry
Thats great, thanks! Saves me the pain of 'cutters remorse'.
/ Quickie log-drag, (paper-thin MIG weld) #46
Terry
I don't know why I never thought about this - but I'm sure glad you did :D
Thanks for posting :thumbsup:
I'm constantly picking stuff up with chains that are too long and have to be wrapped to take up slack.
/ Quickie log-drag, (paper-thin MIG weld) #47
Well, darn! That is a pretty good idea! I am going to make one of those.
/ Quickie log-drag, (paper-thin MIG weld) #48
So simple! Thanks for sharing Terry. Gonna make me one too! :thumbsup:
/ Quickie log-drag, (paper-thin MIG weld) #49
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=422579"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=422583"/>
Terry
If your skills are up to it, you can weld two weld-on hooks back to back. Much smaller, could even fit in a pocket. Just be sure the weld is sound. Or you could cut a similar shape out of steel.
/ Quickie log-drag, (paper-thin MIG weld) #50
Or, pull the pins holding them together and hook the two clevises together. You will need to replace the pins with a grade8 bolt that is just long enough to have the "shoulder" for the whole clevis area.
Aaron Z
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A58375)
2007 FORD F750 XLT...
2013 Freightliner M2 TA45M Altec Bucket Truck (A60352)
2013 Freightliner...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
