Quickie log-drag, (paper-thin MIG weld)
/ Quickie log-drag, (paper-thin MIG weld) #41
I'd use a wire rope come along, with slip hook on the wire rope. Two wraps around the log, clip the hook on the wire rope with bail of hook facing tractor, and working end of come along at top of picking frame.;)
/ Quickie log-drag, (paper-thin MIG weld) #42
10' chain will handle a 30" log depending how much tail you need to get on your implement and how close you can get the tractor.
I have an 8' and 12' with slip hooks for skidding. 12'er mainly helps when I can't get close enough. Then I have chains with regular hooks to extend with if needed.
I have four 20 footers. Every time I go out I wish i'da cut one into a couple 10s, always forget to do it when I get back. This post is my reminder.
/ Quickie log-drag, (paper-thin MIG weld) #44
For a quick way to shorten chains, make up a couple of these and keep one in your tractor tool box.
Terry
Thats great, thanks! Saves me the pain of 'cutters remorse'.
/ Quickie log-drag, (paper-thin MIG weld) #46
Terry
I don't know why I never thought about this - but I'm sure glad you did :D
Thanks for posting :thumbsup:
I'm constantly picking stuff up with chains that are too long and have to be wrapped to take up slack.
/ Quickie log-drag, (paper-thin MIG weld) #47
Well, darn! That is a pretty good idea! I am going to make one of those.
/ Quickie log-drag, (paper-thin MIG weld) #48
So simple! Thanks for sharing Terry. Gonna make me one too! :thumbsup:
/ Quickie log-drag, (paper-thin MIG weld) #49
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=422579"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=422583"/>
Terry
If your skills are up to it, you can weld two weld-on hooks back to back. Much smaller, could even fit in a pocket. Just be sure the weld is sound. Or you could cut a similar shape out of steel.
/ Quickie log-drag, (paper-thin MIG weld) #50
Or, pull the pins holding them together and hook the two clevises together. You will need to replace the pins with a grade8 bolt that is just long enough to have the "shoulder" for the whole clevis area.
Aaron Z
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
208320 (A58375)
208320 (A58375)
2019 Peterbilt 520 Heil Side Loader Garbage Truck (A55973)
2019 Peterbilt 520...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
Bobcat T590 (A60462)
2017 Freightliner M2 106 T/A 26FT Reefer Box Truck (A59230)
2017 Freightliner...
