How to attack this fence line ?
   / How to attack this fence line ? #11
Tracked skid steer with mower on the front. Lift, advance, and drop. Repeat as needed.
Avoid the fence. :)
Bruce
   / How to attack this fence line ? #12
Mini excavator. That 350 yards is about 5-8 hrs. Work with one. 8-10 if you want to leave the fence.
   / How to attack this fence line ? #13
I had the same problem only my "brush" was mesquite trees. I was quoted 7K for a crew with saws to take it back 20' from the fence.
I dove in with the Cat and grappler and cleaned it up in two days. Again these were trees with hard wood.
This video is sped up to not waste your time.
I did lose a $100.00 windshield, but only cost me some tome and fuel. Thinking I saved $6,500.00
   / How to attack this fence line ? #14
My old falling brushed up fencelines are getting dozed into a ball and left in a hole to dry out. Then I'm installing new, and after the old dries up, I burn it. Whatever wire is left I ball up and toss in the dump trailer and drop off with other stuff to the recyclers. After that I cover the hole up and reseed the grass. Mine looked much like yours do...
   / How to attack this fence line ? #15
What kind of fence is under there? Wood or wire? And do you run animals yourself and need to maintain the fence?
   / How to attack this fence line ? #16
Do the recyclers take burned up and oxidized barbed wire? I have a pile of barbed wire, chicken wire, hog wire, hot wire, etc. that I have been wondering what to do with, some pretty rusty. If so, I have a trailer full of metals as it is and it can just go on top.
It's a barbed wire fence. We don't run any animals now, we converted over and grow jigs grass for hay. A couple of months ago I was seeing a couple of horses on the other side, so I have to be careful not to open up a way out for them. I like the idea of the ratchet rake for now. In some spots, the growth has creeped 5 or 6 feet onto our side, so I have room to work in areas without disturbing the fence. If I do compromise the fence, I'll just patch it up. My goal for now is more to clean the brush up back to the fence vs having a pristine fence line.
   / How to attack this fence line ? #18
Not really sure what they take. They recycle metal, so any spare scrap I have gets dumped at their place. I work the same hours they do so I generally am there when they're not. They leave the gate open on a lot for the public to come in and drop stuff off and license plates are monitored going in and out. If they had a problem with me dropping off old rusted fence I'm sure I would have heard by now. Generally there is some stuff in my loads they would typically pay money for, but since I'm only around after hours I just drop it with the rest. I guess if the fence wire is useless to them, the aluminum, old batteries, and whatever else happens to make that load makes up for it.
   / How to attack this fence line ? #19
350 yds is not a lot. Once you get behind the brush you should have good access to the stumps. Spray is certainly an option although not very precision. If it was me i mow as close as i could to it to - I would use my sickle bar and reach under it. Then i would cut a path in behind it and start cutting and being sure to put Tordon or equivalent on the fresh cut stumps to make sure they don't grow back. let it dry, pile it and burn it.
I have done this to my fence line about every ten years but then I got smart and bought the sickle bar which will reach under the trees and bushes and keep it trimmed back so it doesn't get too wild. I mow it at least once a year now and it is a lot less work.
Went and picked up a rachet rake from TS and tried it out on a random spot. I have to admit I'm impressed with it so far and I'll only get better at using it.
Before shot and after shot. Definetly going to need a pole saw to reach in and cut limbs that are overhanging the fence.
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2018 Toro Workman MDX Utility Cart (A56857)
2018 Toro Workman...
2017 Ford F-350 Flatbed Service Truck (A56858)
2017 Ford F-350...
DEUTZ MARATHON...
ST225/75R15 Trailer Tires (A55788)
ST225/75R15...
