Loader Bucket Build
/ Loader Bucket Build #1
jb1390
Gold Member
Southeastern CT
Mahindra 3550, Hitachi 120-2
I'm building a new bucket for my Mahindra. The stock bucket was too small, and I wasn't completely happy with any of the options for prebuilt buckets I found. Saved some money by building my own, and I believe I'm getting a much better final product.
The structural material is Hardox 450, I had much of it sheared to size at my local steel supplier before I picked it up. This stuff is crazy strong, but will bend before breaking so it's a good choice for a bucket material.
Before I welded the bucket together, I did some research on welding Hardox. The bottom and sides of the bucket are 1/4", the rear and top are 3/16". The manufacturer does not recommend preheat for material this thin, which was definitely a time saver. They also recommend a filler material of 70 KSI or lower to prevent cracking. I welded using my Hobart 230 with ER70S-6 wire.
I also did a butt weld test with a small piece of 3/16", ground the welds flat and bent it to ensure the sample was free of cracks.
The addition of a plate in the lower rear of the bucket is necessary to increase torsional strength. As a comparison, using Solidworks, a 100 pound load placed on one corner, with the opposite edge restrained, resulted in a deflection of 1.5", from the bucket twisting. The addition of a plate reduces that deflection to less than .050". The real world results confirmed this.
I could not see the cutting edge from the tractor seat when the bucket was rolled back all the way, so I trimmed 2" off the top lip and adjusted the sides as well.
Bucket looks pretty big from this angle.
It's 34" deep, 79" wide, and 26-27" high.
/ Loader Bucket Build #6
Nice looking job. I recently purchased my first good welder, a Millermatic 211, and hope to start using it and becoming reasonably proficient in the foreseeable future.
I had some issues when welding the cutting edge on the back, due to lack of heat and possibly some hydrogen embrittlement. Each weld on the back let go over a 30-40 minute period after welding. I had clamped the edge to the bottom, to close the small gap that existed, which is why the welds were under stress.
Without knowing exactly what material the cutting edge was made from, had to do some guesswork. I think it's an AR400, but the place I bought it from couldn't tell me.
2nd time through, the cutting edge got 150 degree preheat with oxy acetylene, and the welds got postheat with a mapp gas torch for a minute or two. This combined with some higher settings resulted in no cracks.
I waited about a half hour after stitching the edge to ensure I didn't hear any popping, then welded it full.
For reference, cutting edge is a 6" by 3/4" thick piece.
Added wear plates to the bottom because they look cool and add a little strength and durability. I seriously doubt that 175 KSI 1/4" material will ever wear out on my 50 HP tractor.
Did multiple passes to attach the mount plate, as well as multiple passes to build up the bead at the corner by the cutting edge. Too much heat will soften the Hardox, so keeping the settings somewhere in the middle of the machines capability and multiple passes where required seemed to work best.
3 chain hooks on the top lip, and a D-Ring with chain hook on the inside of the bucket in the middle. The top lip is also reinforced in a triangular shape, similar to the bottom rear but not as exaggerated. It tapers from 3/8" (two 3/16" sheets side by side), to about a 2.5" thick section where it meets the rear of the bucket. It should keep the top lip from bending under a chained load for sure. Anything really heavy will use the inner chain hook anyway.
Wire wheeled the welds to remove slight oxide layer, carbon and copper, and sprayed primer on the clean metal. The hardox comes with a primer, so unless I ground it off I left it alone.
Only thing left now is some black rustoleum paint, then I'll put it to the test.
/ Loader Bucket Build #11
Wow, beautiful work!:thumbsup::thumbsup:
I've never worked with Hardox material, heard of it tho.
/ Loader Bucket Build #13
Very nice!
If you end up using it to dig up some rock or stumps, you may need to "wrap" the cutting edge around the sides by bevelling some cutting edge and doing a full root pass weld up the sides a foot or so. It adds a tremendous amount of strength to the front corners for digging.
/ Loader Bucket Build #14
Very clean work!
Too much bucket for my little machines.
I did add some chain hooks to the bucket on the Hurlimann, but now wish I would have only put on some slotted plates. It seems like I end up wanting to wrap chain around the inside of the bucket often enough that the "out side only" chain hooks are just that much annoyance.
/ Loader Bucket Build #15
If you don't mind me asking, how much did the metal cost? What is the lift rating of your loader?
I believe I'm in the 600-700 pound range. my loader will do 2700 to full height, 5100 breakout.
Significantly heavier than stock, but I don't think it's out of line for what the machine will do.
Very nice!
I was originally going to double up the front edges with 1/4 Hardox. I changed my mind however, and decided to rely on the higher cost material and 175,000 psi yield that comes with it. I don't think I will have a problem, but I figured if I do, it's not really much effort to add extra edge down the line.
It'll definitely be hitting some rocks. It is remarkable however how tough and strong Hardox 450 is. I couldn't drill it, and had trouble bending a 3/16" by 1" piece in a vice with a hammer.
I'm in the $1300 range for material including the cutting edge and skid steer adapter plate. I also still have some decent size pieces of hardox left over, which will be nice for backhoe bucket repairs, etc.
I bought all the strips sheared out of 4x8 sheets, I plasma cut the end plates and cut the 79" dimension.
The cutting edge (3/4" x 6") and adapter plate were $340 alone.
I'm planning to sell the original bucket, I hope to get back 500-600 from that.
Very clean work!
I'm curious to see in practice what i end up using. I have 3 chain hooks I installed on my stock bucket, which work nicely. That bucket is too small to merit an inside chain hook / d ring. I suspect I'll primarily use that inside hook on the new bucket unless i need multiple attachment points.
I'm also planning to build a much smaller, lighter hoisting fixture for the loader, so for really heavy loads I can adjust the hook point to bring the load close to the hinge pins, and won't have the weight of the bucket to lift as well as the load.
/ Loader Bucket Build #20
Will your loader be able to lift it full of gravel ?
New/Unused Landhonor8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A64280)
(INOP) 2013 MACK...
2022 CATERPILLAR 313GC EXCAVATOR (A65053)
2022 CATERPILLAR...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63689)
2023 Kubota...
100-gallon L-shaped Portable Fuel Tank (A66408)
100-gallon...
