Do I have a "real" problem ?
/ Do I have a "real" problem ? #1
SARG
Upstate New York
NH T1030- NH T1530 - 49G Brockway
I recently bought a used NH T1530 tractor and it had a skid loader tire on the front -- one side only. The prior owner had sliced the original R4 tire and bought the skidloader tire and new wheel over the internet. Because the original R4 that was on the machine had 380 hours on it ..... I opted to buy a new duplicate of the Lifemaster tire that had just been put on the machine.
Today I had a new Woods brush cutter and forks delivered. The guy that delivered the items asked what was up with the front tires. I explained what had happened and he said I now have a major issue because the 4 WD tractors have a ratio in the axles built in and if the front tires are a different size from stock i.e. the circumference is different the front axle will eventually give out & that will cost many thousands of dollars to repair. He also said that as long as I don't use the 4wd feature it wont hurt the machine.
The front tires on the machine now are between 1" and 1.5" inches taller than the R4s that were stock.
Do the experts here believe I have a potential problem ?
/ Do I have a "real" problem ? #2
What size was the tire you took off and what size was the tire you put to match the other side
All were 10-16.5
/ Do I have a "real" problem ? #4
Couple things, better to have fronts a hair too big and pull against rears then too small and being pushed. You shouldn't be using 4wd on paved hard surfaces anyways, so there will be some give in the surface anyways. I wouldn't spend a ton of money or time sweeping it; but others may disagree
/ Do I have a "real" problem ? #5
Also consider how much you are going to actually USE 4WD.
A LOT of us "Harry Homeowners" struggle to put 200 hours a year on our machines.
It might take 10 years to become a potential problem.
/ Do I have a "real" problem ? #6
If thats diameter youre probably OK. 5 to 7% lead is ok - seldom more. Youve added less than 5% above what you had stock.
larry
/ Do I have a "real" problem ? #7
This might be the other way around. The front tires are supposed to lead the rears at a certain percentage. As long as they are rotating faster than the rears at the percentage guidelines the manufacturer recommends for the particular machine, you should be ok. As a result, my understanding is that smaller tires might be less troublesome than larger ones.
If not in 4wd for long periods, you may not know a wit of difference , If you are worried about it, I'd use 4wd sparingly but I still think you're ok.
/ Do I have a "real" problem ? #8
This might be the other way around. The front tires are supposed to lead the rears at a certain percentage. Larger tires actually decrease the percentage of lead. Smaller tires might be less troublesome than larger ones.
If not in 4wd for long periods, you may not know a wit of difference but if you are going to keep things the way they are, I'd use 4wd sparingly.
Hes got the tires of larger than normal size on the front - not rear
/ Do I have a "real" problem ? #10
I know. I explained it better with some editing of my original post.
If he has bigger, they should be pulling faster at the ground. I had to double think it after your post. If front tires are rotating at X speed; and bigger tires are X plus; that would be better than slower.
Regardless, 4 wheel drive isn't intended for constant use on hard surface, and if it was me, I would not buy new tires. I might however make a mental note to use 4wd only when needed. After all, if you have no slippage, you don't need it. Might want to avoid using 4wd to push "just a bit farther" into a pile, ect
/ Do I have a "real" problem ? #11
You are addressing this in an indirect way and easy to misinterpret I think. ... The ratio lead is set up mechanically to deal with the tractors intended F/B tire sizes. Usually so that the fronts try to pull the rears by covering 0 to ~ 7% more ground. They slip instead by that percentage. If a larger front tire is substituted it slips more, trying to cover even more ground. This gives a greater lead % even tho mechanical drive ratio is the same
/ Do I have a "real" problem ? #12
"Slippage"(if you are referencing this as it applies to traction) I'm not sure is what manufacturers are trying to communicate as much as "lead" in terms of revolutions or "rolling circumference ratios". A larger tire will revolve less as it gets taller for the same distance but will cover more ground in it rolling circumfrence. My understanding is that if the fronts are always supposed to be "leading" when 4wd is engaged or revolving more to cover the same distance as the larger rear. A larger circumference tire in front reduces the amount of "lead" as it applies to revolutions but increases the amount of rolling circumference ratio. "Lead" in this case is being measured by me in revolutions and not rolling circumference. Basically, all this is measured in ground travel. Dividing the rolling circumference of the front tire with the RC of the rear will give a certain ratio. If this percentage is within 2% of factory ratio, should be ok with no problems due to binding.
All that needs to be done is to acquire the rolling circumference of both front and rear of the old tires and divide the front by the rear. Then find the rolling circumference of the new front tires and divide that by the rears. If these figures are within 2% of each other, he's ok.
To get "rolling circumference" multiply the diameter of the tire by pi or 3.14. This gives " free hanging circumference" . To get "rolling circumference", this number is reduced by things like tractor weight and tire pressure. By multiplying the "free hanging circumference" by 97%, one gets a fair assimilation of rolling circumference.
Hope this clears up some of the confusion from which can be a confusing topic.
/ Do I have a "real" problem ? #13
It all depends on how much work the front tires do when the
mule is in four wheel(four shoe) drive.
The front differential will spin slightly slower than the original tires
and wheels due to the circumference.
The major issue is whether you have a no spin differential versus a
standard slipping differential in the front and you have to be careful
when turning on pavement and rock hard ground by only executing the
turns slowly.
You did the right thing in buying the identical tire for the opposing side
as you would have been up "****ts Creek" without your mule otherwise.
The high wheel row crop tractors used for irrigated row crops/ridge tillage have the same issue with larger front tires but as long as they are identical there are no issues.
It all comes down to torque and horsepower and load against said horsepower that provides said torque per revolution.
Your turning radius is going to be larger because the front tires are larger.
For what its worth people install high wheel tires on all sorts of mules for row crop work so no issues there.
/ Do I have a "real" problem ? #14
I dont think it is confusing at all, but your explanation does help make it so.
/ Do I have a "real" problem ? #15
Ground speed is not dependent on the rolling circumference; it is dependent on the rolling radius measured vertically from the centerline of the axle to the ground.
/ Do I have a "real" problem ? #16
If it was mine I would go back to the size tire it came with from the factory. Or play it by ear until you hear a squeak squeak and then a grind and front wheels quit pulling. I know it makes this sound because my front pinion went out this winter. 600 for the ring and pinion plus seals and my time to fix it
/ Do I have a "real" problem ? #17
Tires wear at different rates that is some of what the "lead " compensates for. The front tires on my 5083e have wore at least 2 1/2 " while the rears have wore considerably less. No problems for me, but I do not run in 4wd on any paved surfaces. I believe your tires will be perfectly fine , just don't run in 4wd on paved surfaces ( never should anyway). By the way I bet they last a lot longer than standard r4s would anyway.
/ Do I have a "real" problem ? #18
I believe you are correct. It is too verbose. To the op: just divide the front rolling circumfrence by the rear RC. I have previously explained how to find rolling circumfrence.
/ Do I have a "real" problem ? #19
If I understand your second post correctly the same size tire was used to replace the original. According to the manufacturer of your Lifemaster tires, they should have identical size except for tread pattern. The Lifemaster is a replacement with the obviously different tread as shown in your picture but it is supposed to be molded on the same carcass. Like its name says, this tread is used for longer life on hard surfaces such as concrete and asphalt, and also damages turf less than the standard tread. From their info, if you bought their Solideal Hauler R4 is the same except for your expensive tread.
On guidance from another source I checked the listed factory specs between the the Solideal and the original Titan R4s.
It seems the diameter is less than 5/8 different i.e. 30.9 vs 30.3"
The original R4 that I replaced must be very worn compared to new.
I also found out from the original dealer that the T1530 started out as a lease vehicle in a nursery pulling wagons around. Could be the bulk of the 360 hours were on a roadway.
KJ K4020 40'x20' Carport Shed (A60463)
KJ K4020 40'x20'...
4'x6' Stack of Sheet Metal (A60463)
4'x6' Stack of...
2006 LIGHTIN 125HP AGITATOR DRIVE GEARBOX (A59823)
2006 LIGHTIN 125HP...
(INOPERABLE) DYNAPAC DOUBLE DRUM ROLLER (A58214)
(INOPERABLE)...
36"x12' Stacks of Sheet Metal (A60463)
36"x12' Stacks of...
2017 Caterpillar 308E2 (A60462)
2017 Caterpillar...
