Flail Mower Ford 917 Flail Mower
/ Ford 917 Flail Mower #21
I live in the northeast corner of the state Leonz. Near Alpena on Hubbard Lake. I also live downstate near Brighton but its starting to suck paying for 2 houses! :)
/ Ford 917 Flail Mower #22
Is there any reason the gear box can't be filled with grease like is often done with a bushhog? Mine leaks 90w or AW68 from around the pto "spud". How difficult/expensive to pull pto stub and reseal? I gave $150 for a ?48" (53" wide) Ford-917 with the duck foot hammer-knives.
Also is there a video or some sort of guide on how to sharpen the hamer-knives (angle and how sharp are the really suppost to be). I use mine to mow lawn, which is mostly coastal/pensacola bahia, and it leaves a lot if the seed stalks just beat up, till first rain when they stand back up.
The manual for the 917A mower calls for "Ford 137 grease" in the gearbox. I haven't tried to buy any, I'm assuming its #00 grease.
/ Ford 917 Flail Mower #23
It's called a banded belt (http://www.vbeltsupply.com/bandedconvetionalbelts.htm), and should be used rather than two singles. I think mine is a B63-2 or perhaps B64-2. Given all the idler adjustment, either should work. Banded belt = less slippage. Also, not only should the knives swing on the hangers - the hangers should swing on the brackets. Is you don't have that double flex, premature knife damage can occur. And no, one that knife there should be a matching pair of beveled cutting edges. A flat edge will result in a more ragged cut
//greg//
/ Ford 917 Flail Mower #24
//greg//
I didn't check the D-rings but I will now. I'm gonna guess this is something I would want to lube-up pretty good at the end of the season? How much bevel am I looking for on those blades Greg? Thanks.
/ Ford 917 Flail Mower #25
Tossed my old blades, haven't had to sharpen new ones yet. So best guess is 25 degrees. Take note that these are heat treated (hardened) blades. Care must be taken not to overheat them, as that can make them brittle
//greg//
/ Ford 917 Flail Mower #26
This old thread seems to be where the knowledgeable posters hang out -
I see a 74" offset 917 flail mower for sale. Claimed good condition, ready to use. I've read through the maintenance/repair suggestions here.
How much hp does it take to run this? I have a Yanmar rated for engine 24 hp / pto 20 hp that is roughly a 7/8 scale 8N in terms of what it can do. Also a 15/18 hp smaller Yanmar that is probably too small, its 3-point is rated to lift only 550 lbs. (both are shown in my sig file below).
Any advice welcome! Thanks.
/ Ford 917 Flail Mower #27
I don't think there's anyway you'll be cutting thick 12" grass or weeds with a 74" @ 20 hp, let alone any brush. I have a Kubota L285, 28 hp @ pto and a 48 or 50" ford 917. I don't bog down in thick grass, although I often takes a trip back the opposite way to cut it well; but I don't think mine would work well over 60".
What are you wanting to cut?
/ Ford 917 Flail Mower #28
Orchard grass occasionally up to 36". The reason I'm thinking of a flail mower is to better pulverize the orchard pruning debris (3/8", occasionally up to 2") that was overlooked gathering larger material for the burn pile. Also the offset will be valuable to mow closer to the trees without banging my head.
This picture is a little more harsh than typical. That's the 15/18 hp Yanmar with a 4 ft rotary mower. In the photo it went downhill fine in the highest gear. I made it most of the way back uphill in range 2 but had to stop and shift to range 1, crawl, to get through this tall area.
Here are more photos I posted along with that one:
Mowing: Big twin (YM240) vs little 3-cyl/Powershift (YM186D)
163274d1272316572-mowing-big-twin-ym240-vs-p1590065rym186dmow3-jpg
/ Ford 917 Flail Mower #29
I don't think there's anyway you'll be cutting thick 12" grass or weeds with a 74" @ 20 hp, let alone any brush. I have a Kubota L285, 28 hp @ pto and a 48 or 50" ford 917.... I don't think mine would work well over 60".
The more I think about this - if a 50" needs 28 hp then a 60" is too big for my 15 or 20 hp Yanmars. Oh well... If anyone wants this, its on CL for $875. 2 hours north of San Francisco.
/ Ford 917 Flail Mower #30
Insufficient PTO horsepower aside, you don't have enough lift capacity either. Never put it on the scale, but I'm thinking my 917 weighs something in the neighborhood of 660 pounds. My JD3720 has 35 PTO horsepower, and have already bogged it down when shredding through some of the thicker patches of crabgrass.
//greg//
/ Ford 917 Flail Mower #32
I was already convinced the one I saw is too big. But here are specs for the modern version:
John Deere 370 Flail Mower $4,200
Model Year: 2005
Used less than 20 hours.
72" Cutting width, 81" wide overall
Weighs 904 lbs
30 HP Minimum required
Center mount - not offset
No way will my equipment lift the offset equivalent of that!
/ Ford 917 Flail Mower #33
Watching and learning as I get my 917 up and preforming . 88" 917 flail fine cut knives pulled by 5210 JD 4X4 turf tires Fel
/ Ford 917 Flail Mower #34
Greg_g thanks. Do I remember correctly that you started out with a YM240?
Yup. My first tractor after retiring from the Navy. Four Chinese and a John Deere since then.
//greg//
/ Ford 917 Flail Mower #35
Had a 917 given to me couple days ago. Needs roller bearings. Shaft from gear box to belt pulley has been ran with frozen bearing. Needs builtup where bearing froze and ground down shaft. Knives are very good. Lookin forward to trying it out in a few days. I'll post some pics and updates as I repair it.
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A63118)
2023 New Holland...
Miller Millermatic 212 Auto-Set MIG welder (A63118)
Miller Millermatic...
Ingersoll Rand 185 Compressor (A64047)
Ingersoll Rand 185...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A59823)
2018 FREIGHTLINER...
2010 Deere 318D (A60462)
2010 Deere 318D...
New/Unused Quick Attach Pallet Fork Frame (A61166)
New/Unused Quick...
