CalG
Super Member
- Joined
- Sep 29, 2011
- Messages
- 9,363
- Location
- vermont
- Tractor
- Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
I purchased a selection of components from one of the commercial members of this forum , that I might add a three spool loader valve in line with the aux hydraulics on my Hurlimann.
The install went just fine, lots of tubing bending and fitting fitting ;-) Everything works very nicely with one exception.
The 1/2" quick couples leak!
At first I thought it was any of the many threaded connections on the spool valve, (the valve it's self is ORB) but I put a paper towel around the connector, and sure enough.. it was the quick couple it's self doing the leaking.
I swapped to a second piece that I had purchased, (always buy extra and save shipping fees ;-) the leakage is reduced, but still drips down the valve mount etc.... Annoying!
So the couplings were new, and still leak. Will new o-rings fix them? Or are they just inadequate? There is a degree of flex associated with the full travel of the loader arms, but there are a pair of hoses and couplings following the same path, and only one leaks.
Or should I just bite the bullet an go buy "name brand" from the local hydraulics shop.
Sometimes, a good value seems like no value at all.
