Home-made mini tractor 4*4 with the joint joined frame
   / Home-made mini tractor 4*4 with the joint joined frame
Many of rain fell, and the time holden, had to dress in a bog garden
   / Home-made mini tractor 4*4 with the joint joined frame #102
Powerful tractor! Beautiful job making it and using it!
Spring cultivation
Is it a dry Spring for you Vladimir ? Or does your field just drain very effectively or quickly ?
Regards, Dave.
Yes, I have a watering earth for summer. Many spring rain. Sincerely, Vladimir
   / Home-made mini tractor 4*4 with the joint joined frame #107
   / Home-made mini tractor 4*4 with the joint joined frame #108
Vladimir, you may weld or fit by bolts a piece of steel (or edge iron) above each wheel closely so it'll be able to wipe the soil clumps from the outer side of wheels.
На колесах была резина, и земля не прилипала, вчера намотал скотч, тоже не прилипает. Скребки можно установить, но будут заклинивать при попадании корней. Спасибо.
   / Home-made mini tractor 4*4 with the joint joined frame #110
In my place it is the same. When I disk I have to periodically stop and clean it otherwise it looks rather like a roller:laughing: That stuff stick to any tools.
And here is my attempt to write in Russian. I use Google translator but then I edit the text so it actually makes sense.
На моем месте это тоже самое. На пример когда я диск мне надо периодически остановить и очистить его в противном случае это выглядит скорее как ролик. Этот материал (когда влажный) придерживаться каких-либо инструментов.
Я работал два года в Росии на постройке газопровода почти 36 лет тому назад и там я приучился Руский язык.
I am impressed by your craftsmanship and ingenuity. You motivate me.
2014 INTERNATIONAL PROSTAR (A58214)
2014 INTERNATIONAL...
1957 Chevrolet Bel Air - 2-Door Hardtop, Period-Correct Engine (A56435)
1957 Chevrolet Bel...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2006 Cummins DGBB 35kW Standby Diesel Generator (A56857)
2006 Cummins DGBB...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
2017 John Deere 35G Mini Excavator (A55973)
2017 John Deere...
