Home-made mini tractor 4*4 with the joint joined frame
   / Home-made mini tractor 4*4 with the joint joined frame
Many of rain fell, and the time holden, had to dress in a bog garden
   / Home-made mini tractor 4*4 with the joint joined frame #102
Powerful tractor! Beautiful job making it and using it!
Spring cultivation
Is it a dry Spring for you Vladimir ? Or does your field just drain very effectively or quickly ?
Regards, Dave.
Yes, I have a watering earth for summer. Many spring rain. Sincerely, Vladimir
   / Home-made mini tractor 4*4 with the joint joined frame #107
   / Home-made mini tractor 4*4 with the joint joined frame #108
Vladimir, you may weld or fit by bolts a piece of steel (or edge iron) above each wheel closely so it'll be able to wipe the soil clumps from the outer side of wheels.
На колесах была резина, и земля не прилипала, вчера намотал скотч, тоже не прилипает. Скребки можно установить, но будут заклинивать при попадании корней. Спасибо.
   / Home-made mini tractor 4*4 with the joint joined frame #110
In my place it is the same. When I disk I have to periodically stop and clean it otherwise it looks rather like a roller:laughing: That stuff stick to any tools.
And here is my attempt to write in Russian. I use Google translator but then I edit the text so it actually makes sense.
На моем месте это тоже самое. На пример когда я диск мне надо периодически остановить и очистить его в противном случае это выглядит скорее как ролик. Этот материал (когда влажный) придерживаться каких-либо инструментов.
Я работал два года в Росии на постройке газопровода почти 36 лет тому назад и там я приучился Руский язык.
I am impressed by your craftsmanship and ingenuity. You motivate me.
2019 Hefty 16' Landscape Trailer, VIN: 5NKBU1620KP011139, Tandem Axle, 48" High Steel Cage, GVWR: (A59076)
2019 Hefty 16'...
2011 Toyota Camry (A55758)
2011 Toyota Camry...
2012 Ford F-750 Pak-Mor 16 CuYd Rear Loader Garbage Truck (A56858)
2012 Ford F-750...
MACK T/A DUMP TRUCK (A58375)
MACK T/A DUMP...
LOT: Air Hose Reels, 220 V Cord, Electrical Cords, Hand Tools, 2-Wheel Hand Truck (A59076)
LOT: Air Hose...
2016 WINNEBAGO SCORPION 4014 5TH WHEEL CAMPER (A58214)
2016 WINNEBAGO...
