power steering works on one side only
/ power steering works on one side only #1
kl281071
Auckland City
Massey Ferguson 148
hi,
i have a massey ferguson 148 (similar to 135). i topped up some fluid and the power steering works. But only when i turn to the left. when turning to the right it does not work . i have bled the line according to the manual.
/ power steering works on one side only #2
Is your power steering ram mounted in front of the radiator, or a ram at each wheel? I have had this same problem on a 178 and a 240 but the solution depends on which type of power steering you have.
Is your power steering ram mounted in front of the radiator, or a ram at each wheel? I have had this same problem but the solution depends on which type of power steering you have.
I am a complete novice....so my answers might be dumb. The CYLINDERs are on each side of the bit that is attached to the wheels.
/ power steering works on one side only #4
Not dumb at all. You have axle mounted power steering rams. I had that same problem on a mf240
The problem was a combination of worn "O" rings and valve settings in the power steering pump.It only had about 3700 hours from memory. How many hours has yours done?
Due to lack of knowledge I had the dealer fix it.
2003 VOLVO G720B MOTOR GRADER (A66091)
2003 VOLVO G720B...
2017 Ford Escape SUV (A64557)
2017 Ford Escape...
1986 Trailmobile F71T-6UJA 40ft. 32 Ton T/A Flatbed Trailer (A64194)
1986 Trailmobile...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 Brush Cutter (A64553)
2016 New Holland...
2018 CATERPILLAR CB66B DOUBLE DRUM ROLLER (A65053)
2018 CATERPILLAR...
2020 PETERBILT 367 (A65643)
2020 PETERBILT 367...
