Bucket Modifications. Pictures please.
/ Bucket Modifications. Pictures please. #1
Eric C
Alabama
John Deere
I have a John Deere 4520 with a standard bucket. I want to beef it up, add a teeth bar, add pull hooks, etc. I plan to use it clearing some medium size undergrowth on my property. I would appreciate sharing pics of your custom bucket for ideas. Many Thanks!
/ Bucket Modifications. Pictures please. #2
Eric, two search terms will return hours of reading for you, try "toothbar" and "hooks" to see lots of ideas.
Kenny...thanks for the link. Will be ordering some of your hooks for sure. Going to check and see if anyone else wants any to save on shipping cost. Great stuff.
/ Bucket Modifications. Pictures please. #4
I have four 3/8" chain hooks welded on top of my 72" bucket and a BXpanded piranha tooth at installed.
/ Bucket Modifications. Pictures please. #5
3/8" angle across the top with hooks and 3/8 plate on the side leading edges. Zero bending thus far. :thumbsup:
/ Bucket Modifications. Pictures please. #6
I have a WR Long toothbar and 3 bucket hooks.
The hooks on each end of my bucket are bolt-ons.
The center hook is a welded on 3/8 grab hook.
Thanks for the photos and ideas. I'm making a plan for mine.
/ Bucket Modifications. Pictures please. #8
I used some 3" X 1/4" C channel welded to the top of my bucket then welded 3/8" grab hooks. Not very good pics but gives you a idea. I don't have any painted pics.
/ Bucket Modifications. Pictures please. #9
I just went with a pair of standard weld on hooks.
After helping my brother in law with a trench using his tractor and backhoe, I had an idea for my tractor... He had dug up several large stones too big to get with the hoe bucket and we had to use a chain to lift them out. Between the chain we had to use, the stones the good Lord blessed us with, on the hillside we were on, biggest issue of all of it was getting the chain to stay on the hoe bucket. Here was the idea:
Built the weld up big and ground it smooth(ish) to cut through the earth and not get hung up on something. I've done hundreds of feet of trenches up to, and in some places exceeding 8 feet deep and it's never brought me anything but smiles being where it is...
As for do they hold well? Here's 1000+ pounds + leverage:
/ Bucket Modifications. Pictures please. #10
Yes, this way!
I've also done it like this but the angle up. This gave me the opportunity to weld on some 4" rings on the back (in the corner created by the angle) for rope/sling attachment also.
/ Bucket Modifications. Pictures please. #11
here's mine. STILL haven't painted... Arg.....
/ Bucket Modifications. Pictures please. #12
Aftermarket Bucket Spade.
aeblank you have the hardest part done. Your bucket looks well built.
How do you like that bucket spade jeff9366? Is it bolt on?
thanks for sharing the pics guys.
/ Bucket Modifications. Pictures please. #14
/ Bucket Modifications. Pictures please. #16
Here's what I did,
I welded one hook onto a mounting plate that I bought from Ken's on the lower portion of the rear of the bucket. I also welded a shackle mount to one of Ken's plates and welded it to the underside of the bucket lip inside the bucket. Combined with a clevis shackle I can use that for a single point lift using straps for lighter items.
I got a length of 3/16X3X3 angle to set on top of the bucket lip which I welded to the lip and to the back of the bucket. 1 hook in the center and the other 2 centered on the FEL arms. I added 2 small shackle mounts that I got from Ken's outboard of the hooks, again just for lighter lifts with nylon straps.
/ Bucket Modifications. Pictures please. #17
Here's what I did,
Nice work.
/ Bucket Modifications. Pictures please. #19
/ Bucket Modifications. Pictures please. #20
Has anyone done chain hooks to double wall top portion of 300cx loader as a bolt on?
Or is welding the only way?
Max
2013 DODGE RAM 2500 CREW CAB TRUCK (A64280)
2013 DODGE RAM...
2023 NISSAN ALTIMA SEDAN (A59914)
2023 NISSAN ALTIMA...
19-gallon Portable Sandblasting Cabinet (A66408)
19-gallon Portable...
2021 Sany SMG 200C-8 Motor Grader (A62679)
2021 Sany SMG...
Kivel 42in Forks and Frame Mini Skid Steer Attachment (A64553)
Kivel 42in Forks...
FORD 5 BOTTOM PLOW (A64278)
FORD 5 BOTTOM PLOW...
