Max 28 XL Loader Quick Attach?
/ Max 28 XL Loader Quick Attach? #1
mitchash
Gold Member
Greene, NY
Mahindra MAX 28XL, Jinma 254 (Sold)
My Max 28 that I bought last spring does not have a quick attack loader bucket. I thought I seen on here someone had a new Max 26 that did have a quick attack loader bucket? Is there any way this could be adapted to the Max 28? If so how much? I do have a set of fork lift forks that I had a quick attach plate on. Now I was going to make a pin on plate and use it on the three point hitch.
/ Max 28 XL Loader Quick Attach? #2
There are some folk that have made their own and I think there was a company that at one time was going to produce a pin on SSQA loader adapter but I'm not sure what ever became of them. You can search the web and this site for "Mahindra Max SSQA" and find some results.
The biggest challenge with doing such a thing is you're hanging a couple hundred extra pounds of weight between the pins and the load which moves the load out farther from the tractor. That in turn reduces the overall lift capacity by well more than the amount of weight added by the SSQA hardware because the load is out farther. It also can reduce the stability of the machine at full capacity and height. Just moving the load out away from the tractor a couple inches can really change the center of gravity fast.
/ Max 28 XL Loader Quick Attach? #3
If the new Max26 has the same loader AND the new QA, there shouldn't be much lost retrofitting it onto a Max28, don't you think?
/ Max 28 XL Loader Quick Attach? #4
I dunno on aftermarket, but I doubt the QA setup on the max26 adds a couple hundred pounds of weight, I would think (looking at it) 50, maaybe 100 total
/ Max 28 XL Loader Quick Attach? #5
I am wondering.... Do you find that the Quick Attach is really an asset? I have looked at the "Everything Attachments Web site" and they will get you set up with the QA. It is somewhat expensive, and will require some modification to the O.E. bucket.
My brother is in the (scrap business) and gave me a set of forks without the mounting hardware to attach them to. That same site mentioned above has the 'backboard' to retrofit them to the tractor. I looked into the idea of a quick attach myself....but am worried about the added weight and reduction in lift. So my quandary is; "Is it that hard to pop the pins and attach the different implement"? Are the buckets on these tractors hard to maneuver when unattached? They are smaller in size so my predicament is go ahead and fab a pin on forklift attachment..... but that is a lot of work to find out that I should have went on and done the QA thing.
/ Max 28 XL Loader Quick Attach? #6
Yes trying to align the pins is a challenge even with the smaller bucket. If you can get the top pins in then the bottoms become easier since you can now lift the bucket and tilt (dump) it until the bucket swings somewhat free making aligning the two bottom pins a tad easier. Another problem is the grease. On my loader all of these pins are greased and also have anti rotation pins (bolts) that would require the pins be installed in a certain orientation.
The attachment is a picture of a semi-pin on quick-tach conversion.
/ Max 28 XL Loader Quick Attach? #7
I am wondering.... Do you find that the Quick Attach is really an asset? ------------------. So my quandary is; "Is it that hard to pop the pins and attach the different implement"? Are the buckets on these tractors hard to maneuver when unattached? They are smaller in size so my predicament is go ahead and fab a pin on forklift attachment..... but that is a lot of work to find out that I should have went on and done the QA thing.
My suggestion is, remove the bucket, drive the tractor around and put it back on. Do it again to see if it is any easier the second time. That might convince you to go with a QA.
/ Max 28 XL Loader Quick Attach? #8
You both make a good point! Quick Attach is a good thing; but maybe I should give it a shot and remove the bucket as you suggested. Take it off and put it back on. To see for myself just how difficult it is.
I pose one last question, "how often do you use the QA on your loaders"? Once a month, or couple of times a year?
/ Max 28 XL Loader Quick Attach? #9
It would have been nice to up the curl cylinders to 40mm from 35 mm when they add the SSQA
/ Max 28 XL Loader Quick Attach? #10
I may get a set of pallet forks from the dealer at some point (assuming they're offered... I imagine they are), but it wasn't a must-have for me. I've taken the bucket off once, and that was to weld stuff to it a bit easier. It's nifty I reckon, and for someone who plans to use the loader for more than material moving probably a nice feature to have.
bigger curl cylinders would have been nice, esp for popping things up outa the ground (like.. smallish trees), but that probably plays into the strength of the loader as a whole.
/ Max 28 XL Loader Quick Attach? #11
It depends on the project, could be 4 or 5 times in a days work with the tree puller and grapple.
Three times when setting out a hay bale for the horses, remove whatever is on the SSQA, put on the hay spear, set out the round bale, remove the hay spear.
But I don't have a tractor and I do have a lot of attachments, since there is no three point lift, everything is done on the front.
/ Max 28 XL Loader Quick Attach? #12
And just to show that I have experience with pin on attachments, I have been using this for over ten years.
I wish that I had built some type of quick attach for it when I put it together.
/ Max 28 XL Loader Quick Attach? #13
Xfaxman
You have interesting machinery!!! Is it a lawnmower, telehandler, forklift, or just one versatile machine? Obviously the equipment you use has Quick Attach, no way I am hooking up a grapple that size to my tractor!
The little guy- The mini skid steer..... You stated you wish you had QA on that? That validated the question I asked; much appreciated
/ Max 28 XL Loader Quick Attach? #14
Xfaxman
You have interesting machinery!!! Is it a lawnmower, telehandler, forklift, or just one versatile machine? --------
Yep, it is a very versatile compact telehandler. :thumbsup:
Since it doesn't have a QA, it helps to store attachments on a dolly.
The 4' box blade:
Anyone one find a price on the pin on quick attach mount from the MAX 26XL? I measured one and it looks like it would fit my MAX 28XL.
/ Max 28 XL Loader Quick Attach? #16
can't help you with your question but Mahindra calls it a 'tool carrier'. At least that's what's on the sticker on my 3016 loader.
My dealer said the quick attach conversion for the MAX 28 would be $1200. ! I guess the pin on bucket and forks are just fine for me.
/ Max 28 XL Loader Quick Attach? #18
For me as well. Cannot justify that as I would only "switch out" one time a year; a grapple would suit me better for that kind of coin.
Where and how much are one of these forks? This would be be perfect, I could use it on the three point hitch for the heavy stuff and on the loader for things needed to be lifted higher.
I still haven't been able to find these forks, except for this picture. Anyone know anything about them? They look like they adjust for different loaders and pin on and also mount to the three point hitch.
2017 Ford Explorer SUV (A64557)
2017 Ford Explorer...
2020 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
2016 GMC Sierra 1500 Crew Cab Pickup Truck (A64556)
2016 GMC Sierra...
2012 MACK GU713 DUMP TRUCK (A63276)
2012 MACK GU713...
2018 Freightliner Thor Venetian 400XCR A40 41ft. Class A Motorhome (A64557)
2018 Freightliner...
2002 Harmon Steel Barrel Asphalt Tanker Trailer (A64194)
2002 Harmon Steel...
