B2920
/ B2920 #2
I don't think it has a transmission screen.
/ B2920 #5
if you look at the left hand side just below the filter, you will see a large steel tube along the side of the trans. The screen in under the banjo fitting where the pipe bolts to the side of the transmission housing. I always buy 2 new orings when I clean the screen, might not need them, but nice to have on hand if one of them gets cut when you pull off the banjo fitting.
Dan
/ B2920 #8
Wow, I'm surprised there is no screen. My B7800 has one (Kubota calls it a strainer). Here is a scan of the page from my owner manual that shows where it is.
  • scan0001.pdf
/ B2920 #9
thanks herringvhoker, this should help...
Kubota might have forgotten to install on during the original build. Nevertheless, the attached scan shows it well. if there isn't one on your 2920 Hendrix12, I would recommend you buy one and install it. This screen will prevent a chunk dirt or metal from taking out your hydraulic pump.
Dan
/ B2920
Thanks, my manual doesn't show that. I guess I'll have to wait, I just changed the trans. fluid.
/ B2920 #11
To my knowledge the recent 2009 up BX models have a screen, but the B23, 26, 29 models don't. And if the OE manual doesn't show one, there must not be one...........would be my thinking anyway.
/ B2920 #12
I agree 'oldballs'
My B2650 (2014) does not have one , owners manual does not show one either..... my older B1700 (1996)did.
Case TV450B (A64126)
Case SV280B (A62177)
NEW 2025 Mini Skid Steer Stand On Loader (A62679)
NEW 2025 Mini Skid...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A65054)
(INOP) 2013 MACK...
John Deere 4020 Loader Tractor (A66285)
John Deere 4020...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
