445 Foot pedal extension
/ 445 Foot pedal extension #1
narampa
canada
445 johndeere
About 5 yrs ago I made a real simple extension for reversing my 445. You think one of the dudes in design at Deere John could have had a brain fart and made the pedal easier to use anyway look at the pictures and see what you think.
The block is made from a piece of hardwood.
/ 445 Foot pedal extension #2
That is pretty close to the way I fixed my 455 and 425. Prolly a safety reason that Deere has them going a bit slower in reverse and it was a corporate decision... But I like the peg that you put on yours.. I just formed mine to fit the curve of the pedal and it is glued/screwed to the top.
Yours is prolly more stable and will hold up longer than mine.
/ 445 Foot pedal extension #3
I think these tractors have a bit of a flaw in this area. The bracketry that holds the pedals is marginal at best. With age they will get to the point that they'll barely backup. Anyone that uses these tractors to their limit will always be looking for a way to fix the "back up" problem. Both of your solutions are top notch. :)
/ 445 Foot pedal extension #4
I ordered one off EBay 3 years back and it is a super improvement. Mine runs backwards maybe even faster that forward now.
I think this is the link to the newer version. Mine is just bare metal. Now he has a rubber pad with an arrow on it. $38 + shipping
John Deere 425 445 455 New Generation Revised Reverse Pedal Non Adjustable | eBay
/ 445 Foot pedal extension #5
Well I think I posted the wrong link. I suppose others are selling this also and these might be OK.
But this is the one I put on my LX188 and they are the same pedal per this listing.
They are $32 with free shipping.
John Deere 425 445 455 "Revised Enhanced" Reverse Pedal with Rubber Pad | eBay
Below is a picture that I took of my LX188 when I was installing in.
I took this to show the difference in the original vs the new extended version. (both on the shaft)
So you can see how much higher the pedal sits. Obviously the old one has to be removed.
/ 445 Foot pedal extension #6
I don't find that (flawed, marginal) to be true, and have worked around many of the Deere lawn tractors as well as owned several models in the 400 series. They're intentionally designed for slower reverse (safety nerds at work).
Found the fix was not difficult nor was it expensive (shaping a piece of wood to attach or add as narampa so cleverly did).
I saw this pedal on the net for $32 but I like mine as it did not cost me 32 cents as I used a piece of scrap hard wood.
But I must say the $32 dollar one has some appeal to the eye that mine lacks.
/ 445 Foot pedal extension #8
I have lost track of the number of posters on TBN that have complained that their JDs kept getting slower in reverse. That's what causes the need for threads like this. If it was a Wal-Mart mower I'd accept it. On a JD, it's a flaw. So much so that there are manufacturers selling aftermarket fixes for the problem. Myself and my Sons have used your method to overcome the problem. I wonder if JD would think it acceptable that an owner would have to screw a piece of wood to the reverse pedal?? Hmmmmm... I guess they do as they continued to build them by the thousands that require said modification. :)
/ 445 Foot pedal extension #9
I think what the ebay mod does is overcome the weakness in JD's design so there is no need for future additions of rubber, wood, plastic, whatever.
/ 445 Foot pedal extension #10
Perception of weakness is misguided here. My 425 is no "weaker" now in reverse due to anything with the reverse pedal. Confused a bit over where you get that... apparently with experience with the JD 2210 ??
But whatever, the addition to the pedal allows one to push it further down to gain speed in reverse, not to overcome any weakness in the tractors ability to go in reverse. nuff said from me on that.
/ 445 Foot pedal extension #11
Again, I get that from the hundreds of posts over the years from JD owners who complain that their tractors eventually get where they won't back up as fast as originally. So they start modifying the pedal to gain back that loss. I've not had that problem with my 2210. But it's very common on the 4 series of different models. nuff said from me on that.
/ 445 Foot pedal extension #12
I have a 445 that I have had for seventeen years, with twelve hundred hours, and I have had no problem backing up!!
/ 445 Foot pedal extension #13
Congratulations. :)
I did the mod because I tore the ligaments in my ankle. The tractor has a thousand hours and never has had a problem backing up. The problem was I had to be careful how I stepped on the pedal. It took years for the ankle to heal but that is another story.
/ 445 Foot pedal extension #15
No "problem" backing up either, but from day 1 the reverse was slower by design than forward. With the extension, reverse is just as fast as forward. That was true on all my 425's, 445, and 455 which have been several.
