Gooseneck trailer advice
/ Gooseneck trailer advice #1
Poke
Member
Benton, AR
2013 MF 1533 1960 TO-35
Alright, I've got an opportunity to buy a 30 foot tandem dual gooseneck trailer in real good shape, and sell my 18 foot bumper pull, and be about $1000.00 outta pocket. Question is, I have a 2014 3/4 ton Ford, 6.2 gas with 4.30 gears, is it enough truck? I'm not hauling anything real heavy, my tractor is a MF 1533 and Ranger 570, haul about 12 round bales twice a year for my mother in law, that's about it. I sold my last gooseneck, which was a 20 foot with 5 foot dovetail singe tire tandem axle, and the truck pulled it like a champ. I guess what I'm really wanting to know is how heavy does a trailer this size and the dual tires feel behind a 3/4 ton? I know all about the braking, and I'm not worried about the truck stopping it, because I always keep good brakes on the trailers, and I don't get in any hurry when pulling, I'm just curious if it's gonna pull the truck apart being too heavy and riding terrible. Thanks for any/all replies in advance!!
/ Gooseneck trailer advice #2
What is size,weight/foot of main frame? Had a 30foot with a 30lb/foot main I beam and felt like dragging around a sled. Traded for a 20ftplus 5 with 20lb/foot frame handled backhoe through rookies just fine a pulled so much easier. Pulled with dodge cummins 5 speed
/ Gooseneck trailer advice #3
A 30 ft. dual tandem is probably pretty heavy empty. Find out how much it weighs and check your vehicle GCWR and don't go to far past that wt. you should be fine towing it with the gasser.
That's a good question, the guy that owns it said he took it across the scales when he first got it and it came in at 6700lbs, he thinks, but the pound/foot would probably be near impossible to find out.
GCWR 5th wheel on my truck is 22200lbs, I believe the truck weighs 7100, trailer weighs 6700?, tractor and Ranger together weigh around 5000, another 1000 of gear/tools, so I'm looking at around 19800lbs give or take a beer or 2 lol.
/ Gooseneck trailer advice #7
Do you have a CDL? That trailer likely has a GVW of 20k. Add that to your truck and you are over 26k which means CDL, medical card, log books, DOT number, etc.
/ Gooseneck trailer advice #8
It doesn't sound like you have a need for a trailer that large?? A gas motor will be working hard to pull a trailer that big once you start loading it up.
/ Gooseneck trailer advice #9
Trailer will put you into CDL rules for sure. 6700 lbs seems a little light for a 30ft tandem...
/ Gooseneck trailer advice #10
I would do it. You haul bales twice a year. I'm guessing with a gasser you are not pulling the tractor anywhere regularly, maybe to dealer or once a month at most. You have experience with pickups, trailers, brakes, loads, etc. Should ride better than your bumper pull, by far. You have experience with a 25 foot gooseneck thus know if you can handle 5 more feet. Expertise, care and driving skill are on your side and infrequent use argue for getting it for the extra convenience of having the load length. Check state laws...if you are not hauling commercially and it has farm tags, you may not need CDL.
/ Gooseneck trailer advice #11
I had a 30' tandem Dually trailer and it was 6,800# with nothing on it.
I wouldn't touch a trailer that size without a diesel 1 ton.
Chris
Well after further inspection of the trailer, it was originally a 30 foot deck with a 5 foot dovetail added later. I think we'll be able to take 5 foot off the end and weld the dovetail back on, take a lil bit of weight and length off. I hated to sell the last gooseneck, but a situation came that I couldn't pass on. I go to the deer lease with the tractor 2-3 times a year, and like to take the ranger too, I also own 40 acres about 40 minutes from the house and like to take both sometimes too. My longest distance is 1 1/2 hour one way, so no long distance runs. I also prefer to pull goosenecks, and it limits the number of people who can ask to borrow it lol. I'm pretty hot on this deal, because its a REAL good deal that doesn't come around often. Weather permitting, I'm gonna go get it this weekend and pull it around unloaded and see how it does. Thanks for all the replies!
/ Gooseneck trailer advice #13
That's cheap money! Might be a little heavy but I'd go for it for your use.
2019 AUTOCAR XPEDITOR TRASH COMPACTOR TRUCK (A63276)
2019 AUTOCAR...
2008 12ft. Alumacraft Flat Bottom Mud Boat (A64194)
2008 12ft...
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2021 Ford F-150...
2013 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2013 Caterpillar...
PALLET OF HOG CREAT PANELS (A64278)
PALLET OF HOG...
2013 VOLVO VNL630 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2013 VOLVO VNL630...
