Hour Meter Issue
/ Hour Meter Issue #1
Tim_in_IA
Eastern Iowa
Kubota B7610HSD, Mahindra 6500 4WD, JD 440ic crawler, 2 560 farmalls.
Hi my hour meter stopped working but the tach still works on my 6500. Quick thoughts on what this might be?
/ Hour Meter Issue #2
Is it the old mechanical meter or digital? Give it a tap and see what happens. You may also take the screws out of the dash pull it out and unplug the harnesses then re attach incase something is dirty.
/ Hour Meter Issue #3
The mechanical style may be cable driven and could have broken. If it's electrical check the wiring for a broken wire from the source (probably off the ign key switch) or the ground wire.
/ Hour Meter Issue #4
That is a pretty common problem with the older 00 series. I think the board in the panel breaks down. You can replace the instrument panel or just add a after market hour meter to keep up with service intervals.
/ Hour Meter Issue
Thank you I will check the cable out. Hopefully not the board. I assumed that the hour meter ran of the tach cable but it must have a different connection.
/ Hour Meter Issue #6
Tack will operate from the alternator. Are any other functions not working?
/ Hour Meter Issue
Not really, hour meter is it. Hopefully it's that cable as the board sounds like something more expensive or not available.
/ Hour Meter Issue #8
Hi Tim....I also lost the hour meter a couple of years ago. Took off the
instrument panel and saw nothing obviously wrong. I then hooked up
a diff. meter.
/ Hour Meter Issue
a diff. meter.
Hi! Thanks for letting me know this. I plan on removing the instrument cluster to day to see what kind of cluster I am in. Also replacing my seat as mine is badly cracked. Not sure what to replace with but it has to go.
/ Hour Meter Issue #10
My seat is fine. The reason being, that it is covered by a small tarp when not in use.
I'm short on one end, so I sit on an old wheelchair foam seat. Hense the cover.
/ Hour Meter Issue
Thanks, I started another thread with a picture of my seat if you want to check it out. I've tried covering it but must not have tried enough. Plastic bags etc and the cover always blows off. I got the seat covers but it seems like Mahindra might have changed seats on that machine so the covers didn't fit. I am going to remove the bottom pad and see what the condition of the rest of the seat is. It's a pricey seat to replace. Trying to make it so I can keep this shedded more often.
John Deere CX15 (A64911)
John Deere CX15...
2020 Chevrolet Tahoe SUV (A66738)
2020 Chevrolet...
AGT 2 Post Car Lift (A64912)
AGT 2 Post Car...
John Deere 6200 Tractor (A64047)
John Deere 6200...
Year: 2000 Make: Toyota Model: 4Runner Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 215,938mi (A66738)
Year: 2000 Make...
2009 Kubota RTVX1140 (A64912)
2009 Kubota...
