MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 67,307
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Whoops! I meant to write It. My fat fingers missed the 't'. :ashamed:
You're forgetting that cold is on the right and hot on the left.And pay day is on Friday. All you need to know to be a plumber,.
With the two wires to find underground pipes, loosely hold the short L in each hand so they can turn when you cross pipes. I've done it for underground water lines (under concrete even. My scientific minded buddy didn't believe it until I showed him at his place where I had no idea where his lines were.), sewer lines, and electric lines. Keep forearms about parallel to ground while loosely holding short end of L wire, just hold wires about 12" or so apart, slowly walk over areas until long end of L wires begin to turn toward each other. Probe. Ye've found ye pipes.
Yep, that's the way I do too. I've only done it for water sources to sink a bore (well), haven't tried it for anything else. It should be the same method though... clear your thoughts, think/imagine what you're looking for and slowly walk along (as you've stated above). It just 'happens'.
Not to hijack the thread, but here's a question for the group. Our house is about 30 years old, and we just started noticing that when it rains, you can see the water standing in places where our leach field has settled. Looks like perfectly parallel stripes of water. Is this a sign that our field may be reaching it's "saturation point" and that we may need to dig a new field at some point soon?
I hope not -- we don't have any more flat area back there to dig a new one... Should I be doing something now to help keep this from becoming a problem?
Was only able to find some #12 wire. Will need to visit the hardware store for #18. Anxious to give it a try... Sent from my iPhone using TractorByNet
I used about 1/16" x 36" long brass rods from the "K&S" metals box at the local hardware. Bent the "handles" about 6" long in the vise. Mine work good!
- Jay
OP here. Two photos of my suspected tank location. In photo1 you can see the basement wall and heat pump. Coming directly perpendicular from that wall and about 4 feet from the corner of the house you see a flat rock in the lawn. That flat rock marks 15 feet which is what the health department sketch says the tank is from the house.
In photo2 you will see the flat rock still, in the right. Now looking parallel to the house you will be looking across the tank and into the drain field. The flat rock marks the right side of the tank so it will be extending into the lawn however wide it is from that rock. The drain field extends straight back in the photo to the tree that appears to be above the tarp on the ground. It's all very flat and probably not more than six inches difference from the rock to the end of the field. Honestly, I can't see much of any kind of witness marks. At the flat rock I poked a probe 18" deep every 12 inches in a 10' square there. The ground is hard clay and I gave up after my arms turned to rubber.
View attachment 417526View attachment 417527
What is that sag in the ground about ten feet closer to the camera then the flat rock? I'd probe there.
Well it was a shot.Rotting tree stump... :thumbdown:
Well it was a shot. So there was a tree there when they put the tank in? That puts a limit on where they dug the hole. How far down have you probed under the flat rock?
Logically ( I know that's not fool proof LOL) the waste line should exit the walk-out basement near the toilet down there. That would be the sensible layout. Are there no cleanouts for the waste line that you can see? There could be a cleanout hidden behind the interior wall covering.
Is the flat rock anywhere near/in line with the basement toilet?
You must have some tree roots in the leach field lines if the pic isn't fooling me.
