Ford 1510 Temperature Guage question
/ Ford 1510 Temperature Guage question #1
gschones
Oklahoma City.OK
John Deere 1205R
I am going to go ahead and add a temperature gauge to my 1510. I would like to keep the idiot light operational as well. Is there another location on the motor where I can add the sending unit for this gauge and leave my idiot light in place? Any help from the gurus on this site is greatly appreciated. Thanks, Gary
/ Ford 1510 Temperature Guage question #2
Why not put a "T" in where the idiot light goes into the block or head,
put the light on one branch and the gauge on the other.
Does any one know if the top or bottom hose to the radiator is the return.
/ Ford 1510 Temperature Guage question #7
It should be the top hose, the one with the thermostat.
As I understand it, the thermostat holds coolant in the engine until it reaches operating temperature, then opens so that the coolant can flow from the engine, through the radiator, then returns to the engine by the bottom hose after it's been cooled down.
/ Ford 1510 Temperature Guage question #8
Based on the information provided below, the above would be incorrect if intended as an answer the question posed in post #6.
However, temperature senders and sensors are always (or nearly so) placed on the engine side of the thermostat, or directly in the cylinder head where coolant temps are highest. Maybe this is what Gunny was getting at.
/ Ford 1510 Temperature Guage question #9
Yeppir, I know that a sensor placed in a radiator hose isn't going to correctly indicate block temps, I was just looking for an easier way for this fellow to add a gauge.
The instructions for the linked part I gave also said to place it in the upper hose just before the radiator, probably because that's just the easiest place to install it.
In any case, it will read temps and while they might not be totally accurate in comparison to actual block temps, it will definitely give a reference point in conjunction with the idiot light.
/ Ford 1510 Temperature Guage question #10
Agreed on using the upper hose. Lower hose, not so much. Just a waste of time to put one there.
/ Ford 1510 Temperature Guage question #11
I would put the idiot light sensor on the upper hose and the thermostat sensor in the thermostat housing or wherever the other sensor was.
That makes sense. Thanks for the suggestion.
/ Ford 1510 Temperature Guage question #14
I've been threatening to install a temperature gauge on my 1510 also. I'm very curious to see what you end up doing. Pics, please?
I will post it once I am done. I put a bracket on the tractor to hold the gauge which I bought on ebay. I am set up to just switch them out. I liked the suggestion Thomas H had of moving the idiot light sensor to the hose and think I will do that. Once the snow melts and I have nice day I will get on it and post the pictures.
/ Ford 1510 Temperature Guage question #17
I believe that Hoyes sells the adapter for BSPT to NPT, not sure how much, but if ya gotta have it, ya gotta have
1997 GMC GMT-400 SINGLE CAB TRUCK (A62130)
1997 GMC GMT-400...
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
2019 Ford F450 4x4 Service Truck w/ Tommy Gate (A62613)
2019 Ford F450 4x4...
INOP/NON-RUNNING 2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL8DL188002 (A61165)
INOP/NON-RUNNING...
1998 Ford L9501 Louisville 101 Truck, VIN # 1FTYN90K4WVA35579 (A61165)
1998 Ford L9501...
2016 Case IH Magnum 310 Tractor (A64047)
2016 Case IH...
