weld qa plate to bucket
/ weld qa plate to bucket #1
Professor Marvel
Virginia near Culpeper
Ford 5000, Kubota 2150 HST, NH TC45 D, JD 375 Baby Skid Steer --- STUFF THAT GOES ON EM, Schwinn Stingray
Is a Hobart 210 mvp too small a machine to weld a quick attach plate to a front end bucket?
/ weld qa plate to bucket #2
It is rated to weld 3/8". Aren't your plates 3/4"?
plate didn't look that thick. I will have to go measure it. Thanks
here is the spec from the first weld on plate I found - still don't know if my welder will safely handle it.
•Constructed of 1/4" Grade 50 steel with a 3/8" thick Top Bar
/ weld qa plate to bucket #5
A well burnt in three pass would be acceptable in my book. Are you running hard wire or flux core?
/ weld qa plate to bucket #6
If you're having doubts about the capacity of your welder, here are a few things to consider doing.
Bevel the quick attach plate.
Preheat the weld zones after tacking everything up, just before welding.
Use 100% CO2 gas, with Lincoln's L-56 wire.
Use Lincoln's NR-212 self shielded wire.
Weld everything vertical up hill.
I have been using flux core but looking at Shield Arcs suggestion i will get some Lincoln's NR-212 which i think is also flux core.
is that .45 only or does it come in different sizes?
/ weld qa plate to bucket #9
I think L-56 you can get in .023" or .025", .030", .035", ,045", .052", and 1/16".
NR-212 the smallest I think they sell is .045". You can get .030" in NR-211.
/ weld qa plate to bucket #10
If you have access to both sides of each plate no worries at all. Consider getting some scraps appx same thickness & test your methods. Happy to see Shield Arcs list of tips !
I see they have a NR212 3/64 but I don't know what that is or where I would place it in the chart for heat/speed. Seems to calculate to about .040 is that a size? Would I just split it between .035 and .045 if it was?
/ weld qa plate to bucket #12
3/64" could just be a misprint for 5/64" :confused3:
3/64" = .046875"
Too close to .045" to be needed in their inventory in my opinion?
I have no doubts about your welder having the power for the task.
Do you have experience with welding 1/4" and 3/8" material?
3/64" = .046875"
No i do not have the experience yet. Maybe i better hold off until i get more under my belt.
Lincoln Electric Innershield NR-212 3/64 in. Self-Shielded Flux-Cored Welding Wire-ED026090 - The Home Depot
here is where i saw the mig wire I must have converted it wrong
Thanks
/ weld qa plate to bucket #14
Here is what NR-212 looks like.
First picture is flat.
Second picture is vertical up hill.
Third picture is over head.
/ weld qa plate to bucket #15
/ weld qa plate to bucket #16
Consider drilling the qa plate on the flats and then plug weld it as well as doing the edges.
I drilled three 1" (?) holes on either side of mine (5/16" plate) and plugged 'em ... and then ground them smooth so the tractor-side qa would mate with no issues. Lincoln PowerMig 215 ...
Hasn't come loose yet ... :D
/ weld qa plate to bucket #17
Instead of 2 pages, the simple answer is yes... of course you can.
It concerns me that 1) someone thought a QA plate might be 3/4 thick steel and 2) the OP has picked the plate up before and didn't know it wasn't even close to 3/4 :p
/ weld qa plate to bucket #18
Good point. Also 2 pages in and no pics of the project.
/ weld qa plate to bucket #19
In these lengthy discussions many things will be learned. For example did you look as SA's pictures?? Can you weld like that??
I would agree that a person experienced with metal would know the difference in weight of a piece of 1/4" versus 3/4". But for someone trying to learn, maybe not.
I consider myself an average welder. For me, the most important thing is understanding where the stresses are going to be and how to best overcome them. By that I mean using grinding/angling techniques, different welding positions, etc. Last would be my concerns about the Welder's ability. Operator ability comes first. I'll guarantee you SA can weld it on with a much less capable welder than the OP owns. :)
/ weld qa plate to bucket #20
Feasibilty of the project might come first. Without a pic of the project and the parts, forum assistance spirals off into uselessness. Not that pics prevent that, but they make good help "possible". :D
