Need help bending 1/4" aluminum
/ Need help bending 1/4" aluminum #31
With .250 thickness? How big was your radius?
hugs, Brandi
Material was 1/2 x 3. It was over 15 years ago, but as I remember the radius was about 1.5" The piece was bent into a U shape with about 6" between the legs and there was a flat section between the 2 radii, so they couldn't have been much bigger than that, possibly 2".
/ Need help bending 1/4" aluminum #32
I would be really interested in just what you are making. Aluminum is a very different material than steel.
60 series aluminum dont bend well without heat. But are fairly strong.
30-series are better forming, but about 1/2 the strength
20 series and 70 series are both stronger than 60 series, but also hard to form without heat. They also cost alot more than 30 and 60 series.
I have worked with alot of 6061 and 3003 before. The 3003 is good to work with in sheet variety making bends and such. Used alot of that for guarding around moving machinery where strength wasn't really an issue. But if you get pieces of it mixed up with 6061, results wont be good, as 6061 will snap when trying to bend without heat.
And on a few occasions when strength was needed, I have used 2024 and 7075. But never bent that stuff. It was only used for making parts that had threads or something that would wear out alot faster with a softer alloy.
The type of aluminum is the most important thing to consider first. When I made small brackets and stuff for machinery, the guys in the machine shop always gave me the 30 series type if I was forming or bending it. If I grabbed a piece that I didn't know what it was, and it was the 60 series, it would not bend cold. I would not want to fool around with the heat unless I needed the strength, which I never did.
/ Need help bending 1/4" aluminum #33
But what was the thickness?
hugs, Brandi
/ Need help bending 1/4" aluminum #34
I've bent 6061T6 AL a few times in my hydraulic press. It's not a problem if you bend it around a proper radius. I built a simple jig with 2 parallel bars welded to a heavy base piece. I can put spacer bars in to adjust the open gap, and just lay the piece to be bent across the opening.
I bent 1/8" 90 deg using a 5/8 dia shaft to push with. A friend was building a front landing gear for his homebuilt airplane. We bent 1/2 x 3 into a U shape. I think the radius in the corners was about 1". He made a jig so it could just be pushed straight down and form both corner bends at once.
The problem with welding AL is it loses most of it's strength and will easily bend or break.
This is a simple way to bend it if you are not radius critical. For the best bending use 1100 material with no previous cold working. Most aluminum you buy at a hardware store is 6061T6 - it will not bend well. Go to a metal supply house and get some T0 if 1100 is too soft for you project - preferably 3000 series.
I would start with a bend radius at least 3X your thickness but if you can go more it would be better. The other trick is to make sure your bending punch and die are both very smooth - aluminum is soft and a little roughness will mechanically bite in, localize the stress, and tear it. Don't be afraid to use a little lubricant on the punch and die - you want the aluminum to be free to move int he direction you are forcing it.
/ Need help bending 1/4" aluminum #35
I read lots of advice and quite a variety of grades and tempers from aviation grades to commercial.
Commercial alu is relatively soft but when you get to aircraft alloys you have a whole new world and frankly into a whole different price range. Most aviation grades will have a cladding of pure alu to be corrosion resistant.
A very basic rule of thumb (if the alu is bendable) would be radius=3 X thickness.
Th generally practice would typically to have radius bars which are simply scraps pre bent to then bend your finished piece over.
Otherwise maybe described as bend 3 pieces at the same time with the 2 inner ones being scrap and the outer your finished piece. On 1/4" stock bend it over a 1/2" rod and you should be good to go. (that's for soft material)
/ Need help bending 1/4" aluminum #37
Thickness was 1/2"
What was that part for? Thicknesses are usually called out with a decimal point. Your 1/2 inch thick would be called out in prints as .500. You using 1/2 x 3 was throwing me off.
hugs, Brandi
/ Need help bending 1/4" aluminum #38
hugs, Brandi
It was for a front landing gear on a homebuilt airplane. The wheel went in the middle, like a front wheel on a bicycle.
/ Need help bending 1/4" aluminum #39
You cannot make a blanket statement like that.
I think we have established that it all depends on the alloy and temper of aluminum.
Some will bend, some wont
That's right. Just look at the top of a soda can. The edge is roled over 180ー.
If you had read the thread header, the OP wanted to bend 1/4" aluminum.....
/ Need help bending 1/4" aluminum #40
Yes, that's right. But the 'blanket' statment did not say what thicknes, so it might be missunderstood that all aluminium of any thickness may not be bent past 90 degrees. That's what I was trying to clarify.
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2018 FORD F-150 XL EXTENDED CAB TRUCK (A59823)
2018 FORD F-150 XL...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2012 BIG TEX PIPE TRAILER (A58214)
2012 BIG TEX PIPE...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
2003 Freightiner FLD120 (A61307)
2003 Freightiner...
