New PT1430 arrived.
/ New PT1430 arrived. #41
I hate it when someone points out something obvious that I should have known!!! I only have so much skin left on my forehead from slapping it! On that subject, any of you know how to peel a banana? My kid showed me this method a few years ago.... 50 years of fighting bananas! Yeesh!!! Enjoy. :licking: YouTube Link: https://www.youtube.com/watch?v=nBJV56WUDng
Look at the bright side of it......no one can ever accuse your fore fathers of being Apes or that your family evolved over time from Guerrillas, etc.....because clearly no one passed on the most important trick of opening a banana the right way! ;-)
/ New PT1430 arrived. #42
True evidence of non-evolution and small fighting forces. Thanks! :laughing:
Thanks Ponytug. Already got the radiator back in. Wasn't to bad getting to the bolts after removing the fan. I plan on checking all nuts and bolts if I ever get it off the mountain. Sent from my iPhone using TractorByNet
Got her running long enough yesterday to drive her off the mountain and trailer her home. Going to start trouble shooting whenever the temperature gets up into the 20's or so. That seems to be happening about every 4 or 5 day between 1 and 2 PM. Where's that global warming when you need it.
/ New PT1430 arrived. #45
I upgraded my wheel motors 2 years ago [long story] and you will see the difference. I use my 1430 most days on the farm and it does a great job. The break is a pain but otherwise it is a great tractor.
My 1430 is about 1.5 years old and probably has the same size hydraulic oil filter. It's on really tight. I use a 5 inch band wrench and it works well. NAPA had the wrench in stock. The rubber seal is pressed into the top plate instead of the filter. It would be much easier for me to replace the seal if it was part of the filter.
Does anyone know if there is a Wix filter that cross references for the PT filter?
Bill
Hey Bill. the serial# on my new 1430 is 21843. Would you mind checking yours and see how it compares to mine? trying to get a handle on how long this tractor has been sitting around in the warehouse. Thanks.
Reg
/ New PT1430 arrived. #47
I joined the PT Forum in 2010; today I may have to consider changing my online handle (name) on this forum... :cheerful:
On the downside (as experienced by others with new machines), I soon noticed the first out-of-the-box defect:
The above are both front wheels; it appears to be not-so-clean oil seeping out... :sigh: Looks like I'll have to jack this thing up and perform repair/maintenance before the 1st hour is up... I hope to be able to see where the oil is coming from; hopefully just a hose that needs tightening on the wheel motor.
Cheers,
/ New PT1430 arrived. #48
Welcome! I didn't realize that 1430s came with tilt seats!
It may be too late to mention that you don't want to be using the engine or the wheel motors at full throttle or full pressure for the first ten hours.... Given the current temps in your locale, perhaps a little longer...
My guess is that you have some axial leakage out of the wheel motor(s). With luck, the seals will bed down as you use it more. Could I also suggest that you double check the oil level in the tank?
Can I point out that you can use the front end loader to lift the front end, so that you can get jacks under it? :) You probably also want to get the the FEL on supports for more working room, but make sure that they are strong enough. You don't want it coming down while you are working on the wheel motors.
Congratulations on your new PT!!
All the best,
Peter
View attachment 412806 (bad rotation; sorry) View attachment 412807
Cheers,
/ New PT1430 arrived. #49
Thanks Ponytug, advice appreciated; all things I had thought of trying today. (I'm off this week.)
I hadn't thought that the wheel motor seals would need to 'seat' themselves, but a good thought. I may pull the front wheels anyway to try to confirm the origin of the leak. (Will definitely check the tank level as well.)
The oil seeping out might be clean; it might just looks dirty because the rim surface might be dusty...
Thanks Ponytug, advice appreciated; all things I had thought of trying today. (I'm off this week.) I hadn't thought that the wheel motor seals would need to 'seat' themselves, but a good thought. I may pull the front wheels anyway to try to confirm the origin of the leak. (Will definitely check the tank level as well.) The oil seeping out might be clean; it might just looks dirty because the rim surface might be dusty...
My left front is leaking also. And that's just sitting idling. I think these tractors have been sitting in the warehouse for some time and seals and such could have dried out. Don't think it's a hose because they are in back of motor.
/ New PT1430 arrived. #51
According to Char-Lynn, motors need about 10 hours at half pressure to 'seat' the seals. YMMV. It would seem reasonable that the process might take a little longer out in the cold of winter, but what do I know?
All the best,
Peter
/ New PT1430 arrived. #52
Good to know (even if we do not have Char-Lynn motors?)...
Mine are leaking enough with the engine shutoff that I suspect worse when under pressure and moving... I'll probably pull the wheels anyway to satisfy my curiosity, and then put them back on to see how bad the leakage is under operation.
Peter
Yeah... Noticed that too. I'll be posting a few questions later in a separate thread about some discrepancies on the instrument cluster...
Cheers,
Cheers,
The 1430 uses the same instrument panel as the tsm class. the seat tilt switch is not connected to anything so you have a spare switch to use for something else. By the way, you might want to check that the hydraulic radiator is mounted securely to the hood. mine fell off and landed on top of the engine.
/ New PT1430 arrived. #54
Thanks RegL; I'll double-check the rad; it seems secure...
Didn't get around to taking the wheels off; heard back from PT/Terry to use it as it was meant and call back if the leakage is still there after 10hrs. on the clock. So, that's what I'll do.
I pulled the console covers to see if my Seat Tilt switch is connected. Mine has two yellow wires on one post, and an orange with black tracer on the other post. I haven't tried to see if the switch does anything yet, but I'm wondering if it's not pre-wired for an accessory (left-most position of the key).
Ciao,
/ New PT1430 arrived. #55
When the brush hog arrived, the front casters were wrapped (like Saran Wrap). Low and behold, taking the wrap off revealed Flat-Free tires!! :)
/ New PT1430 arrived. #56
Happy mowing!...in February, in Canada...:)
Sorry, couldn't resist. Merry Christmas.
Peter
/ New PT1430 arrived. #57
That's what they should have been putting on everything since day one! Good for you. :thumbsup:
/ New PT1430 arrived. #59
My new hedge trimmer... ;)
I also got two buckets, brush hog, blade, tow adapter, and three plate adapters.
Non-PT implements coming: minihoe, skeleton grapple bucket, and forks.
Cheers,
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A63118)
Bulk Lot of NEW...
2012 International (A59230)
2012 International...
2016 John Deere 470G Hydraulic Excavator (A64194)
2016 John Deere...
New/Unused Landhonor Tree/Post Puller (A65583)
New/Unused...
2015 Nissan Altima SV Sedan (A59231)
2015 Nissan Altima...
