Oil & Fuel B2920 front axle dipstick stuck?
/ B2920 front axle dipstick stuck? #1
McREBEL
Gold Member
Mississippi
Kubota B2920
From the manual and what I can gather by searching here, this yellow dipstick in the picture (front axle) is just supposed to pull out. I have pried on it with a screwdriver. It just does not want to give. I feel like I am about to break something. I am going to spray a little Liquid Wrench around it when I get home to see if that helps. It is supposed to pull straight out right?
/ B2920 front axle dipstick stuck? #2
I had the same problem, don't use LW, use a pair of channel locks and a piece of wood to get leverage and pry it out.
/ B2920 front axle dipstick stuck? #3
It APPEARS to be a dipstick. It probably has an o-ring and might be stuck to the housing. I would try protecting it with a rag or such and try gently rotating it with pliers. I wouldn't think it has threads because of the lack of a leverage device to open it, but the trans and axle lube check points on my Kubota are threaded.
geneP, It will rotate freely. Just wont come out. It does seem the o-ring is stuck to the housing which would still allow the dipstick to rotate.
Hunter29, Will try the channel locks and wood. I wanted to make absolutely sure from someone who has/had a B2920 that it just pulls out. I didn't want to have one of those "Man, I sure wish I would have asked before I pulled so hard" moments.
Thanks for the replies.
/ B2920 front axle dipstick stuck? #5
I don't remember if it has an O ring or not, either way it is very hard rubber, it will come out but will require a lot of force...
/ B2920 front axle dipstick stuck? #6
Probably slight corrosion above o-ring not allowing to come out.
/ B2920 front axle dipstick stuck? #8
The BX model and my M2620 has the same stick on the front axle. They do fit tight and do have an O-ring seal; but it will pull out if'n you can get enough grunt on it some way. After doing a check, I take some of the fluid and smear it around the O-ring and the hole. But even then, it fits real tight.........which is a good thing.
That Mississippi mud sure is red....helps keep that dip stick seated real good.:D
Cheers,
Mike
Thanks Mike
Haha! That mud makes a great orange dye and is slicker than deer guts on a door knob. I try to stay out of it. I got stuck between a rock and a hard place and had to go through some of it. It gummed up on the tires making them appear twice as wide as they were. I scraped some off and slung the rest off. Ducking occasionally. :irked:
/ B2920 front axle dipstick stuck? #10
My B2620 has/have the same problem. Channel locks help.
Sent from my iPhone using TractorByNet
/ B2920 front axle dipstick stuck? #11
Same issue here!
I've been using 2 of those pocket flat-bladed mechanic's screwdrivers-you know the type your local tech has in his pocket,the free ones.
They sre thin enough to go between the dipstick and the axle housing.
One on each side of the dipstick and it wiggles right out.
I also lube the o-ring.
They are a tight fit-I normally thunk it with a plastic hammer to reseat.
Good Luck!
/ B2920 front axle dipstick stuck? #12
Number two,
I also throw some Vaseline on the o-ring too!:thumbsup:
/ B2920 front axle dipstick stuck? #13
I use silicone grease on mine and it seems to help. They ARE tight! Pull straight up! Twisting is pointless unless it make you feel good since the O- ring will not likely spin with the stck.
Wobble while you pull.
Success! I wiggled it out using a wood chisel. The channel locks and block of wood would have probably worked well too but I couldn't find a block the right size at that moment.
It was more of a pain to get back in. I lubed it up with some of the trans-axle fluid but it was still difficult. Hammered it back in using two hammers with the rubber handled end of one on the dipstick. I hope Kubota has come up with a different plan for the dipsticks on the new B's. A screw in with shoulder and the o-ring/gasket on top would be a big improvement I believe.
In all fairness it is likely mine had not been out since it came from the dealership in 2008. I bought it 4 months ago with only 112 hrs. so it had probably not been out in a while.
