Tractor needed
/ Tractor needed #1
Bryanmarler
Delmar ny
None
Hi. I'm a new member and need a tractor for 3 acres, hilly, some trees. Need FEL, belly mower, and snow blower for 1/2 mile driveway near Albany ny.
Was thinking of a JD 1026r or kubota 1870.
All thought welcome!
Bryan.
/ Tractor needed #2
/ Tractor needed
Agreed. I like this unit but I need a front end loader and snowblower. I don't think it comes with these?
/ Tractor needed #4
Either JD or Kubota would wok fine, we have a BX2660 and JD2305 and use them in the hills with no issues; you can add wheel spacers if needed.
I'm not familiar with the other brand SCUTs, but I'm sure they would work well also.
/ Tractor needed #5
I found the Yanmar SC2450 TLB to be a great tractor, powerful, good FEL has mid power takeoff standard.
You can get the SC2400 it is without back hoe.
The low hi shifter can be moved on the move, I didn't think about it until I got Mahindra Max28, you have to stop to shift.
Not sure but the mid mower maybe a drive over.
Also Yanmar came out with a tractor just a little larger than the 2400/2450, same hp.
Give yanmar a second look.
/ Tractor needed
Do you have a bx1870 in stock with a front end loader, belly mower and snowblower? Can you offer extended warranty. Could I get it serviced in NY.
/ Tractor needed #10
I'm not sure if Ventrac comes with a Snow Blower..:p
/ Tractor needed #11
Bryan.
:welcome: to TractorByNet! :thumbsup:
I just noticed this is in the New Members Forum, they recommend no tractor questions here because this forum doesn't get as many views as the other forums.
Try starting a thread here: http://www.tractorbynet.com/forums/buying-pricing-comparisons/
Another brand made for hilly terrain is: Versatile Tractors,Compact Tractors,Trailer Packages,Landscaping,Utility Vehicle Rentals,Mowers-Power Trac
And the forum here: http://www.tractorbynet.com/forums/power-trac/
2012 MACK CHU (PINNACLE) (A60736)
2012 MACK CHU...
2019 FORD F-250 CAB AND CHASSIS (A60736)
2019 FORD F-250...
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
2012 Range Rover SUV (A61569)
2012 Range Rover...
HITACHI EX550LC EXCAVATOR (A58214)
HITACHI EX550LC...
