Tractor needed
/ Tractor needed #1
Bryanmarler
Delmar ny
None
Hi. I'm a new member and need a tractor for 3 acres, hilly, some trees. Need FEL, belly mower, and snow blower for 1/2 mile driveway near Albany ny.
Was thinking of a JD 1026r or kubota 1870.
All thought welcome!
Bryan.
/ Tractor needed #2
/ Tractor needed
Agreed. I like this unit but I need a front end loader and snowblower. I don't think it comes with these?
/ Tractor needed #4
Either JD or Kubota would wok fine, we have a BX2660 and JD2305 and use them in the hills with no issues; you can add wheel spacers if needed.
I'm not familiar with the other brand SCUTs, but I'm sure they would work well also.
/ Tractor needed #5
I found the Yanmar SC2450 TLB to be a great tractor, powerful, good FEL has mid power takeoff standard.
You can get the SC2400 it is without back hoe.
The low hi shifter can be moved on the move, I didn't think about it until I got Mahindra Max28, you have to stop to shift.
Not sure but the mid mower maybe a drive over.
Also Yanmar came out with a tractor just a little larger than the 2400/2450, same hp.
Give yanmar a second look.
/ Tractor needed
Do you have a bx1870 in stock with a front end loader, belly mower and snowblower? Can you offer extended warranty. Could I get it serviced in NY.
/ Tractor needed #10
I'm not sure if Ventrac comes with a Snow Blower..:p
/ Tractor needed #11
Bryan.
:welcome: to TractorByNet! :thumbsup:
I just noticed this is in the New Members Forum, they recommend no tractor questions here because this forum doesn't get as many views as the other forums.
Try starting a thread here: http://www.tractorbynet.com/forums/buying-pricing-comparisons/
Another brand made for hilly terrain is: Versatile Tractors,Compact Tractors,Trailer Packages,Landscaping,Utility Vehicle Rentals,Mowers-Power Trac
And the forum here: http://www.tractorbynet.com/forums/power-trac/
SHOP MADE MANIFOLD TRAILER (A58214)
SHOP MADE MANIFOLD...
2017 INTERNATIONAL LF687 DAYCAB (A60736)
2017 INTERNATIONAL...
2019 FORD TRANSIT VAN (INOPERABLE) (A60736)
2019 FORD TRANSIT...
2009 FREIGHTLINER CASCADIA (A60736)
2009 FREIGHTLINER...
2017 CHEVROLET SUBURBAN(INOPERABLE) (A60736)
2017 CHEVROLET...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
